MTRX Box
Just a couple of questions re the MTRX unit. - How is monitor level controlled using MTRX from S6 ... is the level attenuated digitally before the D/A or is done with digitally controlled analog attenuation / boost (hopefully). What are the step levels. - Are there configurable dim controls? - Sum to mono button? And on the input side: - Is there gain to accommodate consumer level signals. - Talkbac mic Thanks for any help ... much appreciated. Joe |
Re: MTRX Box
As any kind of fold down is possible (and nameable) it's up to you but you can definitely do that. You can setup multiple types (I have 5 due to multichannel inputs being redirected to different speaker configurations: from a 7.1 folded to my secondary output for stereo headphone where the signal starts from 4 sources while also running a 5.1 and 7.1 sources to my main outs folded to LCR when I'm not wanting to engage my surrounds.) Pretty close to any setup you want. This fold down matrix is between the input and output selection so you have as much flexibility as you want. And, as you can see, you can sum your inputs or make them switched-only. I run summed. Quote:
Yes. You assign what input you want to be the talkback mic. Then the S6 engages it when you hit talkback. If you are new to the MTRX/DAD AX32, I suggest you go through all the videos Westlake Pro (dealer in Los Angeles) made on Youtube. They aren't particularly well organized if you are looking for particular info but between all the parts (one set of parts walked through by a representative and one set of parts from Marti who uses them to running/owning The Dub Stage which is both ATMOS and Barco setup), they cover a lot of the questions you've asked (and seeing it will make how these things are set up make much more sense.) Last edited by BScout; 11-01-2017 at 12:46 PM. Reason: fixed wrong referenced dealer thanks to dr sound's post below. |
Re: MTRX Box
Thanks BScout!
Very helpful and informative ... I'm coming from the analog monitor controller world so things are very different. Best, Joe |
Re: MTRX Box
Thank you for the call out about the DAD AX32/ MTRX seminar I did BUT IT WAS NOT FOR RSPE!!! It was for Westlake Pro and Avid Here is a link: https://westlakepro.com/events/marti...st-production/
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
Re: MTRX Box
whoops. fixed my post above.
Pro Tools MTRX | LukeHoward | Pro Tools | MTRX & MTRX Studio | 170 | 12-29-2017 02:47 AM |
Pro Tools MTRX Tutorial | dr sound | Post - Surround - Video | 1 | 03-26-2017 06:03 PM |
MTRX | antonis | Post - Surround - Video | 2 | 10-26-2016 12:31 AM |
MTRX 32 Ch. I/O Limitation?? | audiobee | Pro Tools | MTRX & MTRX Studio | 13 | 10-20-2016 04:13 PM |
Avid MTRX | Rpro | System 5 | 2 | 10-12-2016 07:40 AM |
