Old 11-26-2020, 04:26 AM
Reckless Erik Reckless Erik is offline
Default Mac system audio and DADman
Help!! How on earth do I connect the system audio output of my Mac (iTunes, Soundminer etc...) into DADman? I know I can physically connect it wired but there must be another way. Dante? HOWWWWW????
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 11-26-2020, 04:33 AM
Marsdy Marsdy is offline
Default Re: Mac system audio and DADman
You could use this: https://www.audinate.com/products/so...tual-soundcard
Mac audio then appears as a source on the Dante network that can be patched into DADman.
Dave Marsden
UK
Old 11-26-2020, 05:37 AM
Sorry Dave but this is just not happening here. What should I be using. Dante VIA or Dante Virtual Soundcard?
[email protected]
Newcomer Audio Post
Old 11-26-2020, 06:07 AM
At last success. The MTRX is talking to the Mac Pro and vice versa via Dante. Whew. That was a process.
[email protected]
Newcomer Audio Post
Old 11-27-2020, 12:54 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
I too started with a Dante connection, but every time when I opend a sesseion with another samplefreq. I had to manually set the mac's dante samplefreq. to the corresponding samplefreq.
In the end I bought an RME AES pcie card which switches automaticly with a samplefreq change.
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
Old 11-27-2020, 02:33 PM
uptheoctave uptheoctave is offline
Had the same problem and for a long time I used an Apollo going into the MTRX via analogue.
I've just bought the 128 channel MTRX Dante Card (as I am out of Dante channels) and that is supposed to SRC.
I'll advise if that is the case when it arrives.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 11-27-2020, 02:48 PM
LukeHoward LukeHoward is offline
I agree, this is really frustrating. Even more annoying is that, at least under Catalina on my Mac Pro, Dante Controller often fails to reset the sample rate of DVS (you can change it but it has no effect).
https://lukehoward.com/
Old 12-01-2020, 09:39 AM
samxnova samxnova is offline
I need some help with bringing both MAC audio and PT via Dante to Dadman.
Dante 1-6 is PT 5.1 routing. and 7-8 MAC Audio.
how can I send MAC AU to PT L&R Audio at the same time? it seems that only one source can be routed to one output or I'm missing something?
UPDATE: got it working by changing Switch monitor to Sum. just want to make sure this is the right way to monitor both Mac audio and PT via Dadman.
Thanks.
Rock Studios Inc.
Old 12-01-2020, 12:27 PM
It is.
Old 12-01-2020, 03:04 PM
creativecontrol's Avatar
FYI - DADman 5.4.4.2 is now available in Avid accounts and I would highly recommend updating to it. It includes numerous bug fixes.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
DADMan 2.1 routing out of Mac Goombot Pro Tools 2020 3 10-21-2020 08:08 AM
DADman disconnects pkingduk Pro Tools HDX & HD Native Systems (Mac) 12 07-26-2020 04:22 AM
DADMan goes wonky Jared_TL Pro Tools HDX & HD Native Systems (Mac) 5 12-29-2019 01:06 PM
DADMan Firmware - When to Flash? jdh95 Avid S4/S6 5 09-11-2019 09:00 AM
DADman and Mojave? jgaz Avid S4/S6 15 06-30-2019 07:25 AM
