Old 11-29-2020, 01:50 PM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Re: PT HDX Cheese Grater roll call
I wish I could justify the cost of the brand new Mac Pro but that sort of investment doesn't make any sense given my current business model.
The way my studio is set up the computer is in a separate equipment room in the back of my control room so purchasing a newer iMac doesn't really work.
I do have a second cheese grater chassis in case my power supply goes or some other replaceable component like RAM. I am very intrigued by Apple's new M1 chip and I'm looking forward to seeing how that new architecture develops over the next year or so. If they put a better chip than the current M1 in a Mac Mini that might do the trick.
So despite the fact that I still don't have thunderbolt and I would like to move up an operating system or two I think the smart thing to do for me is to sit tight.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 11-29-2020, 02:12 PM
pinosmuse pinosmuse is offline
Great to stumble onto this tread.
Still running 10.13 on an upgraded 4,1(to 5,1) cheese grater, with HDX PT2020.11. Running still fine.
I'm looking to update to Mojave, but then I'll need a new graphics card.
What graphic card do you guys recommend? Most cards I find need two power connectors and I have only 1 available since HDX takes the other one.
Or do you have a workaround for that?
HDX-1 MacPro5,1 Raven MTi2, PT12.7
Old 11-29-2020, 02:43 PM
I have the MSI Gaming Radeon RX 560 128-bit 4GB GDDR5.
Works fine but you lose the boot screen.
Will Russell
Old 12-01-2020, 06:26 AM
Farhoof's Avatar
Farhoof Farhoof is online now
All Mac Pro 5.1 cheesegraters here. All HDX2 with an USB3 card taking the third slot. Working on external SSD's. We are going to stick with these untill HDX is obsolete for us. Next step is upgrading the graphic cards for cheap non mac RX560x570/580 cards and that will be the last upgrade for these old trusty machines.
Old 05-03-2021, 04:57 AM
PhiltheGreek1 PhiltheGreek1 is offline
Hi all,
Hope you don’t mind the thread jumping topic a bit here:
I have a cheese grater 5,1 / 12 core full RAM, and I use Pro Tools 12.5 HD software with symphony Mk1 usb in a hybrid summing studio. (SSL Sigma)
I find the system unreliable, lots of crashing, no side chain comp and phasing issues crop up when sessions grow so I was thinking to get an HDX card for it.
Also noticeable delays when recording automation.
I’m is there any can advice on what I can investigate in order to keep the 5,1 going for this? It isn’t flashed.
Also I understand I can just buy the HDX and link to via digilink to the symphony Mk1 (I don’t think I pay the Avid licence for using it because I’m on 12.5 HD software and Avid state it’s for 12.6 and above). Is this correct?
Thank in adv.
Phil
  #16
Old 05-03-2021, 08:31 AM
stargazer stargazer is offline
I’m in the same situation as the OP, but I’m using lots of VIs, too.
Waiting for new M1 machines, thinking about getting a new graphics card to be able to upgrade to 10.14, and move my HDX card to an expansion chassis meanwhile.
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
  #17
Old 05-03-2021, 10:15 AM
To be able to run PT on a supported OS I would need a Metal compatible graphics card.
That would, in my case, also require a Thunderbolt PCIe card and a chassis for my HDX card.
I think I’m gonna try to hold on and wait for new M1 models and the Hybrid Engine for HDX coming out.
What are the options, if any, to run Ultimate HD Native without an PCIe card, using TB or USB?
  #18
Old 05-04-2021, 01:47 AM
Farhoof's Avatar
I'm not sure I understand the problem. Just grab a normal sized metal card (like an RX570, I use one with a single power connector) and you have 3 open slots left for your HDX card or other cards.
  #19
Old 05-04-2021, 05:54 AM
I’ve read so much about difficulties with power connections and compatibility, especially when it comes to single slot cards.
Exactly what brand and model are your RX570?
  #20
Old 05-04-2021, 07:58 AM
dr sound's Avatar
dr sound dr sound is offline
I have 3 Mac Pro 3.46 12 core.
All of the systems are HDX 3's
All three of those are running High Sierra .
I purchased 3 NVIDIA Quadro K5000 4 Gig Video cards.
for them. They are the best cards to use with my HDX cards
because they only use 1 power cable.
All the above systems 64 gigs of ram each.
They are full of SSD's along with a 10 TB rotational drive
for back up in each machine.
I have another 2.66 12 core for Video that uses a Native card .
It has a stock 5770 video card, 64 gigs of ram and an Aja Kona
4 card for video being projected.
We do Immersive Mixing... Dolby Atmos Theatrical and Home Theater,
DTS X and IMAX. These systems are rock solid and are up to the task.
I will update to Mohave as soon as the project I am on is finished.
I purchased my Video cards from Gary of GSharp Music
http://www.ebaystores.com/GSharpMusic
He's the best!!
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Maximizing a Mid 2010 Cheese Grater NoiseRoom macOS 8 09-05-2019 05:51 PM
How is Protools 2018 behaving on the 2010 cheese grater Mac? fourthtunz macOS 12 08-21-2018 08:30 AM
macOS 10.14 Mojave and “cheese grater” Mac Pros jsbach Pro Tools 2018 37 06-17-2018 01:50 AM
Best video card for cheese grater Mac and HDX? johnnyv Pro Tools HDX & HD Native Systems (Mac) 16 05-09-2017 02:42 PM
BEST CDRW to put in new Cheese Grater? Lee Blaske Pro Tools TDM Systems (Mac) 5 09-13-2002 09:05 PM
