Re: Low input Signal
While you have a multimeter use the resistance/continuity mode to check the XLR cable to make sure the pins are connected straight through and there is no break in the cable or signal wires shorted to ground/shield (either one of the signal wire being disconnected or shorted to ground/shield will about halve the signal level). But if it’s the exact same cable you can switch back in and test on the mixer with the mic then you can be pretty sure it works OK. But do that now... if the feeling here is the Mic has reduced its sensitivity a lot then maybe it was damaged, dropped etc. between using on the mixer and the interface. It may be the mic is just low-sensitivity (in general... I will look up the specs later... or this specific one) and your mixer has a higher gain preamp, the preamp on the Mbox are not particularly high gain. Or it could be that the Mbox preamp is just faulty and not producing as much gain as it should (around 60dB??... there might be a spec somewhere). You can do some crude measurements of the gain by outputting a very low level signal on one of the line level outputs (use signal gen with a sine wave at 1 kHz) but the exact instructions depend on how the Mbox implements stuff (esp. if you connect a signal into the TRS line level input... does the mic gain knob still affect the level seen in the Pro Tools input meter?). Let me know if you want to go down that rat hole. Last edited by Darryl Ramm; 11-15-2020 at 02:43 PM. |
OK other things that I should have asked before, at least to clarify...
What mode do you have the C2 in? Lets make sure it in supercardioid mode to start with and you are speaking into the correct input side of the microphone. That means the roll off and pad switch are facing you while speaking into the mic. And the mic is vertical and you are talking into the mesh "face"/side of the mic with those switches are on. So mic orientation like Frank in the attached photo. In supercardioid mode the mic should be sensitive, is a very common mode to work in for voice recording, but is also very directional and you must be using it correctly. That might all be obvious to you, what you are already doing but I have no way of knowing how much you know abut recording or what you are doing exactly. Slide the supercardiod/figure 8/omni switch around just in case it's faulty. maybe try omnidirectional and see if that works better. |
Yes, I'm using the mic correctly. :)
So it seems like I will have to borrow that multimeter again. Or buy one. |
Input setting help (hardware input 1 wants to be Protools input 5) | TheBaron | Pro Tools 2020 | 3 | 07-14-2020 09:14 AM |
Bug report: Print track NOT in input will play input | [email protected] | Pro Tools 2018 | 2 | 12-07-2018 02:22 PM |
M-Audio Fast Track Ultra fisical input 1 appears in VST input 2 | blackpauldays | FireWire & USB Audio Interfaces (Win) | 0 | 07-19-2016 08:43 AM |
Issue Recording Vocals PT12/MBox Pro 3 Input 03 (rear panel) - Works with input 01 | lnc77 | Pro Tools 12 | 6 | 03-28-2016 01:18 AM |
New to MIDI. Input is quantizing. Input Quantize is disabled | LiamSlack | MIDI | 0 | 03-25-2008 08:59 PM |
