Old 02-19-2010, 09:14 AM
tom_lowe tom_lowe is offline
Default Frequently used sounds
I'm working on a project which is a part 2 to something I did a few months ago. There are a few sounds I layered in the original session which I'd like to use again for continuity, is there any way I can copy and paste sounds between the sessions, or use Digibase Pro to achieve this?
I'd really rather not bounce parts of the audio or export session data as they're only small regions.
Cheers in advance.
Old 02-19-2010, 09:21 AM
pindebraende pindebraende is offline
Default Re: Frequently used sounds
Cant you just "export as files" for each individual region, from the regions list menu?
Best wishes,
Mikkel
Old 02-19-2010, 10:11 AM
I could, but then it'd duplicate all the files I already have. Pyramix has a really ncie feature where you can select any audio regions you want, drag them in to the library which will group them all together in one file, then in any new sessions you just drag and drop that one file back and voila, all the original sounds are there.
Just wondered is there's any way Digibase Pro can do something similar.
Old 02-19-2010, 10:26 AM
minister's Avatar
minister minister is offline
I'd look at using Region Groups. You can export and import them. Drag and drop from Digibase Browser or Finder.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 02-19-2010, 02:14 PM
jraabe jraabe is offline
Why not just copy/separate the sounds you want to use again onto some new tracks in your original session, then in your new session, "import session data" and grab those tracks?
If you're worried about duplicating the files, just link to the source on import...
If I remember correctly, region groups don't carry any volume automation with them... not sure if that's important to you or not.
Old 02-20-2010, 04:23 AM
JWalkerPostAudio JWalkerPostAudio is offline
I would also suggest copying to new tracks and using import session data. Another solution could be dragging the sounds to a new catalog in the digibrowser.
-Justin
Justin Walker
Old 02-20-2010, 07:56 AM
Thanks for that. Is it possible to drag sounds from the time line to a new catalog in digibase? Tried it but doesn't want to play ball.
Old 02-21-2010, 02:19 AM
No I don't think you can, but a workaround would be to do a "export region as files" (cmnd+shift+k on selected audio) to an easily accessible open folder in the digibase browser and then drag to a new catalog.
-Justin
Justin Walker
Old 02-21-2010, 04:42 AM
-Justin
Nice one, thanks for the tip and the civil manner in which you gave it, unlike so many on here!
HTML code is On
Pro tools 9 Crashing frequently Ezzycam macOS 0 04-10-2012 05:30 PM
Hitting the wall... all too frequently fman Pro Tools TDM Systems (Mac) 13 05-14-2011 06:31 PM
my new iMac crashes frequently lounis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-01-2008 12:41 PM
Anyone frequently move sessions between xp and osx? McGas Tips & Tricks 6 03-30-2008 08:03 AM
Mac OSX 10.3.4/ProTools LE 6.4 crashing frequently craigh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-02-2004 10:07 AM
