Waves 3.2 on dual G4--why am I getting errors?
I have a fairly up-to-date system that is choking big time on several of the Waves TDM plug-ins. It's a G4 dual 450 with about 1 gb ram, sys 9.1, DAE 5.1.1 with Pro Tools 24 (non-mix) hardware--a d24 card + 2 farm cards. I get the TDM-system-maxed-out error message, and all I'm trying to do is work with ONE stereo track with ONE instance of , say, Rennaissance Reverb! This is with Logic Audio 4.7.3 btw, with 120 megs allocated to logic and about 80 megs to DAE. Any advice out there? I could really use it... [img]images/icons/mad.gif[/img]
Re: Waves 3.2 on dual G4--why am I getting errors?
I had similar problems on a machine that you use. Logic was not able to record an play............!
Emagic told me not to set the memory for this aplication much higher than the prefered size. They also told me that the memory managment in Logic doesnt work perfectly in machines with 1 GB Ram. they told me to remove the additional ram So we removed the 500 MB chip and then protools worked perfect. This bug will be fixed in near future
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Wow...that's pretty interesting. Also--and probably more relevant for me--the documentation says that you need a MIX farm in order to use the Reverborator. Doh! Wish I could afford a MIX system! [img]images/icons/frown.gif[/img]
Ram is your issue, I'm having no problmes at all with 3.2 and my quicksilver 733 with 9.2 os [img]images/icons/cool.gif[/img]
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
Are you using a non-mix Pro Tools system too? If so, are you saying that I need to decrease my ram allocation in Logic/DAE?
Thanks! |
Dual Video Cards in G5: DAE errors...help | Zep Dude | Pro Tools TDM Systems (Mac) | 3 | 10-25-2009 05:32 PM |
Constant 6093 Errors with 002 and Dual 2.7 G5 | djaikon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 07-09-2006 11:18 AM |
G5 Dual 2.5 GHz 002R Buffer Errors | outtaphase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-09-2005 02:41 AM |
G4 800 Dual & Logic errors | mica | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-14-2002 12:54 AM |
B&W G3 Dual Monitor - 6042 errors | seehear | Pro Tools TDM Systems (Mac) | 0 | 01-11-2000 04:03 PM |
