Old 05-14-2007, 07:08 AM
Sonic Nomad Sonic Nomad is offline
Default 002 vs 003 some tests
Firstly, I am no engineering genius – these tests are for my own perusal and I feel that some of you may benefit from them. Sure hope they help you decide on going for a 003.
As I have nowhere to post the uncompressed wav’s they have been encoded to 320kbps MP3 (yeah I know) and then rared and uploaded. Also the hosting site may not be very fast.
Listening to them on a 002, 001 or Mbox may not be as revealing as the 003’s D/A’s are.
In fact in a listening test we did this morning the 003 clocked to a fairly decent external clocked sound pretty good.
All External Clocking is provided by an Eventide H8000 FW. There is an additional take using the H8000's A/D convertors in the last test of each group providing a sort of "reference" for some people.
The packs are as follows;
Pack 1: Acoustic Guitar – Dry - 5MB - Pack 1
021_acstc_002pre_int_dry.mp3
Acoustic Guitar -> SE Electronics Z5600a II -> 002 Pre Amp with Internal Clock
022_acstc_002pre_ext_dry.mp3
Acoustic Guitar -> Z5600a II -> 002 Pre Amp with External Clock via ADAT
023_acstc_003pre_int_dry.mp3
Acoustic Guitar -> Z5600a II -> 003 Pre Amp with Internal Clock
024_acstc_003pre_ext_dry.mp3
Acoustic Guitar -> Z5600a II -> 003 Pre Amp with External Clock
025_acstc_vmp_003_int_dry.mp3
Acoustic Guitar -> Z5600a II -> VoiceMaster Pro -> 003 Pre Amp with Internal Clock
026_acstc_vmp_003_ext_dry.mp3
Acoustic Guitar -> Z5600a II -> VoiceMaster Pro -> 003 Pre Amp with External Clock
027_acstc_vmp_eventide_003adat_ext.mp3
Acoustic Guitar -> Z5600a II -> VoiceMaster Pro -> Eventide A/D -> 003 Pre Amp with External Clock
Pack 2: Acoustic Guitar – Hall - 5MB - Pack 2
These are the same as Pack 1 with the exception of a Hall Reverb – Some may find it easier to hear the differences on these as the “musical-ness” off transients is easier to hear.
Acoustic Guitar -> Z5600a II -> 003 Pre Amp with External Clock (Wordclock)
Acoustic Guitar -> Z5600a II -> VoiceMaster Pro -> 003 Pre Amp with External Clock (Wordclock)
Acoustic Guitar -> Z5600a II -> VoiceMaster Pro -> Eventide A/D -> 003 Pre Amp with External Clock (Wordclock)
Pack 3: Violin – Dry - 3MB - Pack 3
001_vln_002pre_int_dry.mp3
Violin -> Z5600a II -> 002 Pre Amp with Internal Clock
002_vln_002pre_ext_dry.mp3
Violin -> Z5600a II -> 002 Pre Amp with External Clock via ADAT
003_vln_003pre_int_dry.mp3
Violin -> Z5600a II -> 003 Pre Amp with Internal Clock
004_vln_003pre_ext_dry.mp3
Violin -> Z5600a II -> 003 Pre Amp with External Clock (Wordclock)
005_vln_vmp_003_int_dry.mp3
Violin -> Z5600a II -> VoiceMaster Pro -> 003 Pre Amp with Internal Clock
006_vln_vmp_003_ext_dry.mp3
Violin -> Z5600a II -> VoiceMaster Pro -> 003 Pre Amp with External Clock (Wordclock)
007_vln_vmp_eventide_003adat_ext_dry.mp3
Viloin-> Z5600a II -> VoiceMaster Pro -> Eventide A/D -> 003 Pre Amp with External Clock (Wordclock)
Pack 4: Violin – Chamber - 3MB - Pack 4
These are the same as Pack 3 with the exception of a Chamber Reverb – Some may find it easier to hear the differences on these as the “musical-ness” off transients is easier to hear.
Violin -> Z5600a II -> 002 Pre Amp with Internal Clock & Chamber Reverb
Violin -> Z5600a II -> 003 Pre Amp with Internal Clock & Chamber Reverb
Violin -> Z5600a II -> 003 Pre Amp with External Clock (Wordclock) & Chamber Reverb
Violin -> Z5600a II -> VoiceMaster Pro -> 003 Pre Amp with External Clock (Wordclock) & Chamber Reverb
Viloin-> Z5600a II -> VoiceMaster Pro -> Eventide A/D -> 003 Pre Amp with External Clock (Wordclock) & Chamber Reverb
I may do some more with spoken voice. Please let me know if these help. Pehaps someone can host the uncompressed 16bit or 24bit files.
David
Old 05-14-2007, 07:39 AM
685 685 is offline
Default Re: 002 vs 003 some tests
System info
https://duc.avid.com/member.php?u=57185
"please stop OVER-complicating simple things"
Old 05-14-2007, 08:15 AM
Naagzh Naagzh is offline
(Clocking the 002 externally is a rather dodgy thing to do!)
It's important not to prejudice the rest of us! Wish you'd have left that little editorial out, but big kudos for doing the tests!
But you don't mention what external clock you used. And what Eventide A/D are you using?
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 05-14-2007, 08:23 AM
Sorry, didn't mean it that way.
David
Old 05-15-2007, 06:56 AM
NickH NickH is offline
Hi David,
Firstly, thanks for taking the time to do these tests!
I downloaded the Acoustic dry files as they are most useful to me as a reference…
I listened to them in PT through my Apogee D/A
& studio monitors…
Sorry to be picky here, although I could hear some big differences in the files, they sounded much more like differences in mic placement than differences in pre amps etc… ( I am not saying that you changed the mic position, rather that the player (being the unreliable organic life form that they are) tends to shift position when playing & between takes…
This makes it very difficult to judge between subtle differences when they can be caused by mic position or pre or a bit of both…
I would love to hear a similar test with a re-amped electric guitar for instance, where the mic & source positions can be utterly fixed & the same exact source can be used for each test…
Many thanks for all your hard work... and sorry if I am coming across as being picky...
Nick
“It’s because you touch yourself at night... ”
System Specs
Old 05-15-2007, 07:10 AM
Hi David,
& studio monitors…
Nick
You raise some very valid points. This is why I asked both the Violinist and guitarist to do her and his best to stand still during the recordings and "swap out" off gear. I then proceeded to do the recordings paying attention to both their constancy of position, levels and other recording snags.
I do plan on recording some samples from a Juno-106 and think your idea is good too. Will look into this.
David
Old 05-15-2007, 07:12 AM
Hi David,
However, having said all that, I will give you my impressions of the Pre’s (as far as I can discern, bearing in mind my post above…)
The 003 sounds by far & away the nicest to me, with the 002 coming in second, not too far behind the 003, but sounding harsher in the top end…
The Voicemaster pre, just sounded like any other Focusrite Platinum pre to me, nasty harsh & thin… and very far below the other two… (sorry, I did try and think of something nice to say about it...)
Cheers
Nick
System Specs
Old 05-15-2007, 07:20 AM
Hi David,
Cheers
Nick
Well not having anything else to compare it with in this country that is.... the South African Millenia Media folk have been kind enough to offer a STT-1 Demo unit. This may be what I need to help hear the difference between an entry level and pro Pre.
The reason I have the Voicemaster there is more for Voice Overs.
What Monitors are you using?
David
Old 05-15-2007, 07:51 AM
Cool, it would be great fun to test that!
Don’t worry about it too much, it’s all subjective & I am sure a good engineer can make a great sounding record with any pre, (to a given value of any) it’s just a lot easier with some of the nicer ones…
I am a little more sensitive to the platinum pre’s as I have recorded quite a few albums through those pre’s in a Control|24 & became hyper aware of their shortcomings… So maybe I am a little too biased against them… Plus I have never used the ‘Voicemaster Pro, just the old Voicemaster, and no doubt the other features of the Pro more than make up for the pre…
Oh & was just listening at my home studio, not at work, so I was monitoring through some Yamaha HS50’s & a HS10, so nothing special, but the room is quite well treated though as I sometimes mix here..
Cheers
N
System Specs
Old 05-15-2007, 08:00 AM
[QUOTE]
Nick
Nick,
I've never done re-amped recordings. But I suppose thare's always a first time.
Any pointers?
A freind has a Marshall Valve State 65 Watt & Epiphone Gibson Les Paul. Do we go straight in or through his Korg AX3000? or should look a another unit?
David
dverb tests DJ FADE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-10-2007 10:51 AM
24/96 davec tests? Tyler Crawfprd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-15-2006 02:06 PM
hey.... what about the MAC DaveC tests? JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-16-2005 01:02 PM
FTP tests SPC Pro Tools TDM Systems (Mac) 19 07-06-2003 08:43 PM
FTP tests SPC Post - Surround - Video 12 07-06-2003 07:45 PM
