Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
  #51
Old 10-04-2017, 08:28 PM
edwardzhouquan edwardzhouquan is offline
Default Re: Fast Track Pro Drivers Windows 10
I've got the same issues with you that the driver 6.1.11 for Fast Track Pro will make Blue Screen Crashes every few hours under Win10 Pro.
From the previous discussion, it seems that when running under Win7, nothing bad happened, and the driver runs well. Therefore, I guess that, is that a way to force the driver running in Win7 Compatible mode?
From the driver downloading page: http://avid.force.com/pkb/articles/e...ck-Pro-Drivers
We may find that the driver 6.0.7 is the latest one that supports Win7 32-bit and 64-bits, but NOT for Win 8/8.1.
I have uninstalled the 6.1.11 and rolling back to 6.0.7, under my Win10 Pro computer. It seems running fine till now.
Has anyone tried this method and any error occurs?
  #52
Old 12-09-2017, 09:28 AM
ekt ekt is offline
Hi
Windows7 64 - Fast Track Pro - drivers v 6.1.10
no BSOD yet, but (as someone has reported previously) drivers are preventing Windows to shutdown properly
I the past I was on a Win8.1 and got the exact same issue - machine would never turnoff
is anyone experiencing the same thing?
  #53
Old 12-22-2017, 02:05 PM
ekt ekt is offline
i've upgraded to 6.1.11 and used it for a few days
the shutdown problem (pc never turns off) seems to be gone, even tough I got a BSOD once while shutting down
but the huge problem is that randomly, while recording, sound becomes CRIPPLED. its like starts to loose samples
last thing I'll try is rolling back to 6.0.7
  #54
Old 01-07-2018, 07:07 AM
ekt ekt is offline
It's been two weeks I'm running with 6.0.7
So far no issue, no hangs on shutdown, no lost samples while recording. Driver does not come up in the process list as a huge cpu consumption (as it was with latest avid drivers).
So to me, for Windows 7 at least, 6.0.7 are the driver to use
  #55
Old 01-18-2018, 08:54 PM
zsoltikj zsoltikj is offline
The latest driver working fully with W10 x64.
  #56
Old 09-16-2018, 10:54 AM
truepack truepack is offline
hi all!
i installed 6.1.12 driver on windows 10 home
well, it works, BUT not properly - there are only 2 outputs detected, 1 and 2
outputs 3-4 are not detected and not indicated by any DAW i'm using (fl studio, abletone, vegas)
is there any solution for this bug?
many thanx for ANY answer!
  #57
Old 11-15-2020, 09:27 PM
wfeschuk wfeschuk is offline
Wow am I feeling out of date ! I am trying to find out if I can realistically expect to be able to run Fast Track Pro on a Windows 10 computer. And if there are recent updates as of 2020? Most references I've found here are from 4 or 5 years ago.
I've read the relevant posts, but am not sure what the verdict really is.
  #58
Old 11-15-2020, 10:05 PM
Pretty much all you need to know is here (the reality is unclear/varies.. you need to try it on your system if you want to take that risk) and on the driver page (not officially supported and won't be, and no updates anymore). https://avid.secure.force.com/pkb/ar...ck-Pro-Drivers
Unfortunately M-Audio lower-end stuff was such a failure Avid dumped the business. Avid just was not/is not set up to do that well. Maybe just time to buy a new interface. Lots of other companies to choose from, including Focusrite, Presonus, UAD, Motu, ... A Focusrite 2i2 for example is not expensive and solves any compatibility issue you might have.
  #59
Old 12-10-2020, 03:09 PM
Originally Posted by truepack View Post
hi all!
This might be as simple as opening IO setup and hitting the DEFAULT button, or manually adding the input paths. Having said that, I agree with Darryl about updating your interface. Most of the M-Audio interfaces were built to a price point and quality was/is sorely lacking. Add to that, M-Audio drivers were never that good, and its not a great outlook. Of course, if your budget is too tight, then keep trying and keep your fingers crossed(but also be prepared to wave the white flag at some point
Fast Track Ultra 8R Windows 10 drivers? Amechan FireWire & USB Audio Interfaces (Win) 9 11-15-2015 11:52 PM
Fast Track Pro, No Sound, Windows 8.1 w/ latest drivers AoyamaJPN FireWire & USB Audio Interfaces (Win) 1 09-28-2014 08:16 PM
Fast Track Pro 6.1.10 drivers won't install on Windows 8.1 64bit Leg@cyGuy FireWire & USB Audio Interfaces (Win) 15 07-23-2014 07:12 PM
Drivers for fast track BFGuru General Discussion 2 10-15-2013 04:25 PM
