Old 09-01-2012, 08:48 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: 003 and 11R SetUp
Originally Posted by Darryl Ramm View Post
You should see something similar on Windows with Pro Tools 9/10... when the Eleven Rack is not used as your interface I then expect you set the sample rate and clock source from the Windows control panel Eleven Rack utility -- is there an Eleven Rack craplet showing up in your Windows control panel?
Darryl
Yeah thats how it is in Windows 7 for PT9 and up.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-02-2012, 03:35 AM
Studio66 Studio66 is offline
When I select Hardware from the drop down Set Up tab it only shows the 003R but all my 11R features work fine.
Going to mess around with it more today and get the Expansion from the Avid Store.
My machine came with IE9 and I'm reading thats not going to work so well....does it need to be completely uninstalled or could I just use Google Chrome instead?
Going to have to read up on the complete install procedures....I believe I read somewhere there is kind of a 2 stage set up.
Old 09-02-2012, 04:48 AM
Default
Read this thread again carefully, should be only one stage for updating the Firmware, you already have the updated Pro Tools plugins in 10.2.
Darryl
Old 09-02-2012, 05:06 AM
Hey gang...dropped IE9 and dl'd the expansion...click...click....damn....that was easy :)
Everything working flawlessly including the GUI for the 11R.
You guys again were awesome!!!!!!!!!! and cant thank you guys enough...
A quick run just through the new presets and....well...new thread coming
Old 09-02-2012, 05:07 AM
Darryl
You were right (as usual) and it went smoothly!!
I appreciate your time and help!
  #16
Old 09-02-2012, 10:16 AM
Benoni's Avatar
There is some sort of conflict when installing the Firmware and IE9. As you have found, you must uninstall IE9 before you run the firmware updater portion.
Now that you have it installed you can re-install IE9 as there are no known conflicts with IE9 after the firmware updater has been installed.
Enjoy the ERXP.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
I/0 setup weirdness, sessions overwrite my setup digidesigner Pro Tools TDM Systems (Win) 0 10-20-2011 11:40 AM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
OMS Setup: Interface Req'd? Setup referrences? eltornado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2000 04:17 PM
