Old 06-24-2020, 06:22 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: HDX-card, Radeon RX 580 8GB and power consumption
Originally Posted by stargazer View Post
Are there any Mojave compatible graphics card that only needs one power cable available?
Apple has a list.
Some are not flashed like the AMD Radeon Pro WX7100
1-6pin power
Old 07-08-2020, 09:07 AM
Padje Padje is offline
MSI Radeon 560 Aero ITX 4G
No startup screen. Not flashable as I know, but besides that, works like a charm on a Mac Pro 5.1 with HDX and UAD, all drive bays occupied, 4k screen.
Old 07-22-2020, 07:11 AM
epm epm is offline
As Padje mentioned the MSI Radeon 560 Aero ITX 4G is (imo) the best solution.
4k Support, fully PCI powered.
No startup screen, but Recovery mode works so I don't see any need for flashing. I'd keep your 5770 or whatever mac card you have just in case, but the 560 is a perfect fit for these machines, and can be found for about $170ish.
-Evan
Old 09-27-2020, 02:03 PM
RossH RossH is offline
Originally Posted by DetroitT View Post
Hi. I use the 580 mac video card.com flashed
The two mini 6pin pcie power to 8 pin video.
Power split / spliced to avid 4 pin hdx
2-evo ssd’s, 2-10tb spinners
Hdx1
I’ve been using this split 8 yr or so since the
Original 5870 card, 7950 now the 580
Mac video cards also offers a single power cable solution (6 pin to 8 pin)
Hi DetroitT, I've seen you mention your "power split" solution in a couple threads on here. Can you provide more detail on how you did that?
I have a 2012 Mac Pro that I want to upgrade the 5770 to an RX580, but am struggling to figure out the power requirements as I also have a single HDX card. And I don't want to add an external power supply, I'm just trying to get another year out of my system.
Thanks for any info.
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's
Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer
Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo
Old 09-30-2020, 02:25 PM
Hugh-H Hugh-H is offline
Hello RossH,
For our MP5,1 + RX580 + HDX3 installations initially I wired the harnesses, one MP 6-pin to the RX580, the other MP 6-pin to both the RX580 and the HDX3 harness. The thought in my head was that the RX580 requires high current and the reason most power harnesses are dual-6pin is to allow for the high currents, less voltage drop.
However I did some voltage and current testing and perhaps the dual 6-pin source is advised for high end graphics software but for audio software and video rendering, it's not necessary. So to make it easier for our other users we purchased single 6-pin to 8-pin harnesses for the RX580 installations, and the other 6-pin on the MP is for the HDX3. Works fine.
Here is the link we purchased that works -
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Good luck.
Hugh
  #16
Old 10-02-2020, 08:39 AM
Hi Hugh, thanks for the response.
Which RX580 are you using? The ones I've seen only have one 8 pin power port. I'm planning to get a Sapphire RX580, I guess mostly because it's on Apple's (now archived) list of supported cards.
I do use Adobe Creative Cloud apps on this Mac, so I think I will need both mini 6 pin ports for the single 8 pin connector. I also want to drive at least 3 monitors (can only use two on my 5770) if that matters.
I'll plan to power the HDX card off a SATA port or two. I've contacted Avid support to try and track down the HDX power cable for PC with the Molex connector on it, I don't seem to have the original box anymore. But I haven't heard back just yet. There is a US-based site that sells them online, and there's one from the UK on eBay. Can't find any in Canada.
  #17
Old 03-31-2021, 07:58 PM
clubber clubber is offline
Folks, I am about the pull the trigger for an HDX card and I have an RX580 4 GB in a 5,1. I am not very familiar with power cables and stuff that needs to be connected to the mainboard and the cards. Please help me out.
I remember having to buy this power cable in order to connect the RX580: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  #18
Old 04-01-2021, 06:23 AM
Hdx1
Hi, can you please elaborate on this 'power split solution"? How do you do that?
Thank you.
  #19
Old 04-05-2021, 06:42 PM
hugoleitao hugoleitao is offline
Hi
Just got HDX card but my nVidia GTX 680 2GB Mac EFI is using both PSU ports.
I'm on a 2009 mac pro 3.46.
Can anyone tell I to get power working for both please?
  #20
Old 04-21-2021, 09:03 AM
innerbooty innerbooty is offline
Chiming in here also looking for I believe the splitter solution. I am new to HDX and have been slowly configuring a 2009 4,1 Mac Pro for HDX. I flashed to 5,1. Got High Sierra installed. HDX installed. Pro Tools 2021. All working great. I bought an AMD Radeon HD 7970 3GB GPU pre-flashed for Mac that I thought I would install today so I could get a 2nd drive running Mojave. I quickly hit the roadblock of realizing this GPU card requires both PCIe power slots, and one is taken by up the HDX card. Is there a way to work around this? Specific details would be super appreciated! Mike Thornton on Pro Tools Expert describes buy a 6 to 8 PIN adapter, but he glosses over the installation of that part and I am not sure which adapter to get, or where it is supposed to get plugged in. Presumably the port that the current stock graphics card is using? The new GPU required one 8 pin and one 6 pin connection.
Thanks in advance for any advice!
HDX card power consumption stanonbass Pro Tools HDX & HD Native Systems (Win) 0 05-14-2016 10:05 AM
Mix Card Specs , Power Consumption??? Table Syrup Records Digidesign Hardware & Software 1 08-11-2010 09:43 AM
Mbox 2 power consumption? How much of a power load is this spaids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2007 06:27 AM
power consumption of a HD core card? black030 Pro Tools TDM Systems (Win) 3 03-16-2007 09:18 PM
Power Consumption dloeliger VENUE Live Sound Systems 1 03-06-2007 09:13 AM
