Old 02-25-2010, 03:58 PM
alexanem alexanem is offline
Default Session saved on a volume set to Transfer only?
Hi everyone,
I am currently unable to open any of my Pro Tools sessions. I can launch the program, but when I attempt to open any session, or start a new one, I get the following message:
"This session is saved on a volume set to 'Transfer' only. If permitted, set the volume(s) in question to 'P' (Playback) or 'R' (record) in the Workspace."
When I open the Workspace and try to change this "volume" setting on my harddrive from T (Transfer) to P (Playback), I get a message that:
"OS' cannot be designated as an Audio Playback volume because it is not a valid audio volume."
Am I not changing this volume setting in the right place? Does anyone have any suggestions one what I might do to be able to open my sessions again?
Thank you for your help,
Alex
Old 02-25-2010, 07:32 PM
Craig F Craig F is offline
Default Re: Session saved on a volume set to Transfer only?
do you have Read & Wright permissions to the drive?
Thank you,
Craig
Old 03-02-2010, 08:12 PM
cmcmahon cmcmahon is offline
Having the same challenge and yes, we have read-write permissions on the drive.
Any ideas??
Old 05-05-2010, 04:49 AM
DNDBEATZ DNDBEATZ is offline
Had the same problem... This fixed it.. u do exactly what it says... just got to know where to look
Fix: Cancel out of the dialog and, from the Window menu in pro tools, select Workspace. This brings up a window that lists the available volumes (hard drives, etc.). Look at the "A" column associated with the suspect volume. It probably shows up as "T" (for transfer). Click on the "T" and, from the little pop-up menu, select "R" (for record).
Old 03-27-2021, 10:10 AM
paul_g's Avatar
paul_g paul_g is online now
OMG, this thread saved me from having a heart attack. I realize the thread is old, but I just had this Transfer / Copy error. No idea how this value got changed... was working, stepped away and tried to reload my product after installing some plug-ins.
Total panic, then I found this thread. The fix worked like a champ, even on PT 2021... Why does PT allow these values to get changed???
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 03-31-2021, 03:17 PM
More likely that its OSX making the change. I've never had this happen on any Windows setup in 17 years of PT
Old 07-17-2023, 03:22 PM
dhmusicprods dhmusicprods is offline
Thank you very much!
I got the same issue
Session saved on "transfer" only volume mcm15 Pro Tools M-Powered (Win) 4 05-24-2013 11:58 AM
Help! "Session is saved on a volume set to 'Transfer' only" nuemes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-06-2011 05:46 PM
Session saved on a volume set to "Transfer" only Gilles D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-02-2009 02:19 AM
The session is saved on a volume set to "Transfer" only... fiddlecat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-20-2008 03:16 AM
Error Message: This session is saved on a volume set to Tran ckboddic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2007 09:24 AM
