Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 07-14-2016, 06:07 AM
secutanudu secutanudu is offline
Default Preamp for drum recording?
Hey guys,
I am currently using an focusrite saffire pro 26 recording interface. I want to make a serious upgrade. I am thinking of a Lynx Aurora 16 AD-DA converter and dedicated preamps.
Since i"ll need upwards of 14 inputs, I am looking for recommendations on the most cost effective preamps I can buy for tracking drums, guitars and vox. What are your thoughts?
Thanks.
Old 07-14-2016, 07:06 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Preamp for drum recording?
Nothing wrong with the Saffire 40 range of pre's imo
It's not a neve or API but it don't sound bad, and I believe it sounds better than the Behringer ADA8000's
Since cost was mentioned this would be my recommendation
Audient would be a step up from them but not huge amounts of money to move up in audio quality
Daniel
Old 07-14-2016, 07:07 AM
YYR123's Avatar
Midas has a XL48 or something that supposedly sounds good, but I've never tried it..
Daniel
Old 07-14-2016, 07:31 AM
So while I'm looking for the best bang for the buck, I don't mind spending more for a better sound. I can't afford 16 Neve pre's, but I dont mind getting one or for key things like vox, kick, snare, etc.
Old 07-14-2016, 07:37 AM
Interesting. Ideally I'm looking for all analog gear since i'll have the Lynx converter. I do see that the midas has analog out though, i assume it bypasses the built-in A/D converter?
Old 07-14-2016, 08:32 AM
YYR123's Avatar
Yep....looks like it would. But again I repeat I do not own one.
I've owned and used both the Saffire range of pre's along with the ADA8000.
For me AES outs are awesome- free's up some of my analog inputs....but everyone's setup is different
Daniel
Old 07-14-2016, 04:00 PM
As an owner of the Midas XL48, I highly recommend it for at least 2 reasons.
#1-it has lightpipe out so its a great match for your setup.
#2-it sounds head and shoulders better than the focusrite on drums(I also have an OctoPre Mk II Dynamic in my rack). I tested against the Neve and API clones I have(and love on certain things) and the XL48 won handily
http://savetheworldband.com/watch-th...deo-for-bleed/
This is my house Mothertone kit with all the shells thru the Midas. Overheads, hat and ride are thru an ISA-428. Mics are also important and this recording was:
Kick in-Audix D6
Kick out-custom sub-kick
Snare top-Shure Beta56
Snare bottom-EV n/d408
Hat-AT3031
Rack-Audix D6
Floor-Miktek PM11
Ride-Shure SM81 under
Overheads-Miktek C1 pair
Old 07-14-2016, 04:56 PM
Thanks Albee. Keep in mind though I won't need light pipe out since I'll be ditching the foxusrite interface and going for a Lynx converter. Would you still recommend it?
I assume the analog outputs bypass the converter inside the Midas?
Old 07-14-2016, 06:59 PM
YYR123's Avatar
The Lynx should be expandable as well, so if you wanted to in the future you utilize the adat and or the AES
Cool thing I read about this unit that I didn't pay attention to at first was the word clock in/out so you can sync all your outboard and still run your Lynx as master....
B/c the audient only has word clock out....
Daniel
Old 07-15-2016, 06:37 AM
Yes I would . I was still thinking re the saffire but the Midas also has analog and AES outs, and even has a split analog out before the pres(though you would have no use for that)
how to use a preamp on a snare drum rogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-16-2008 09:59 AM
What is your Favorite Preamp for Drum Overheads wolfman_rob Pro Tools TDM Systems (Mac) 20 01-29-2007 06:12 AM
Best all around drum preamp Hank5 Pro Tools TDM Systems (Mac) 3 09-22-2006 08:55 PM
preamp for drum noequipment Tips & Tricks 7 12-19-2002 12:35 AM
Drum Mic and PreAmp King Kong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-30-2002 09:40 PM
