Core Accel Chips usage error 7204
I have a sys based on a accel core card PCIe in a macpro 2.66 and I'm running a 24/44.1 session with some TDM and RTAS plugs inserted
. Engine: 64 voices with two chips for the mixer ADC enabled to 1023 samples The usage window shows the first two chips dedicate to HD engine 3° chip 99% MixrShortDlys 4° chip 99% plug-in sharing 5° chip 99% plug-in sharing 6° chip 80% plug-in sharing 7° chip 100% two revibe instances 8° chip 81% MixrShortDlys 9° chip 57% plug-in sharing. I know that chips that are involved in ADC (3°-8°) cannot be used for other task, but the 6° and the 9° have still free DSP but I'm not able to load any other TDM plug, even a simple 1 band eq. It seems that the sys is full. Can anyone explain this?
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Re: Core Accel Chips usage error 7204
Not all plugs can load on all chips. It may be that the plugs you are trying to use require one of the already full chips.
Recording artist/Engineer/Producer Waves beta tester |
Hi Jeff,
I tried with all plug I have, even with THE TRIM, it seems that the sys is full with no free dsp although the 6° slot shows 80% and the 9° 57%. I done a search on this forum and it seems that some plugs could cause this problem. I'm trying to move plug by plug outside the plugin folder for finding which is this ... I want to be sure there is not a hardware issue.
possible to bypass DSP chips on HD accel cards? | sound_music | Pro Tools TDM Systems (Mac) | 5 | 11-18-2012 06:27 PM |
Hd3 Accel with 8 core Mac Pro and OS X 10.5.1 ERROR!!!!! | DrClisby | Pro Tools TDM Systems (Mac) | 8 | 05-27-2008 02:04 PM |
All these plugs won't open on last 3 accel chips | crizdee | Pro Tools TDM Systems (Mac) | 10 | 03-01-2006 11:36 AM |
Missing chips on Accel card? | Lee Blaske | Pro Tools TDM Systems (Mac) | 6 | 09-15-2003 01:34 PM |
-7204 STILL But what chips? | HeLikesItHeyMikey | Pro Tools TDM Systems (Mac) | 1 | 12-11-2000 06:19 AM |
