Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output
Hey,
Whats the difference between the bounce to disk source as Output or Physical Output. This is new to PT9 i believe. Is there any real difference if the output (titled Master) is mapped to the physical output in the I/O (titled Stereo Out) since they are both outputting the same signal? Thoughts? -EP |
Re: Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Outpu
Thanks for asking this - the new behavior of PT9 (bounce to disk defaults to Bus 1-2) as well as the new bus / output routing is a bit of a pain. Also, is there a way to set the io setup to behave exactly as it did in PT8?
Can anyone explain the point of this new routing? (Not trying to hijack the thread - all of these questions are related.) Best...H |
I think PT9 has a small issue with the bounce source. On my rig, BTD selects the last stereo bus that was assigned(so it might be the drum compressor buss, or a reverb bus, I never know until I go to execute a bounce). This is despite having the main outs set in the IO setup tabs.
so which is better to print from?
physical output or just output? |
Bump.
??? Which do we choose? Im having a hard time telling the difference, I think it's starting to MindF*ck me a bit.. Can someone just explain the difference so I can understand my choice instead of continuing to guess and check? Pretty Please? lol
System Specifications Mac Pro -OS X 10.7.1 LION -3.2 GHz Quad-core Intel Xeon, 2x2x2x2 OWC DDR3 RAM -Pro tools 9.05(Beta) -Snow Leopard Partition with 9.05 -2 1 TB 7,200 RPM Drives -OWC OnTheGo 500 GB recording drive Macbook Pro -10.6.8 OS X Snow Leopard -2.8GHz Intel Core 2 duo, 2x2 DD33 RAM -Pro Tools 9.05 Outboard DBX 160a Compressor> Presonus ADL 600> M Audio Profire 2626 (hopefully soon to be BLA modded)> Presonus Central Station> SurgeX SX1115-RT Power Conditioner |
Physical Output - that's the "real" output, i.e. the output on the rear of your interface
Output - That's actually just a bus. You can route multiple outputs to the same physical output
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
recording to disk in the session your mix is best for me as you can use destructive record and to mini tweaks without having to do the whole tune in real time
a huge time saver IMNO be sure to have the track on input so if you do punch in on a mic the verbs / dly or anything else is captured correctly
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
New Option - Physical Output - Bounce Source? | KingFish | Pro Tools TDM Systems (Mac) | 2 | 03-10-2018 05:51 AM |
getting my G4 select 001 as my output source | jacobsapple | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-29-2009 05:27 AM |
Difference in Output between 002r and digi001 | gwattaloopy1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-23-2006 09:11 AM |
Bounce to disk mix difference | flautista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2005 05:35 PM |
low output level on bounce to disk | Katherine | Pro Tools TDM Systems (Mac) | 3 | 12-11-2004 10:20 AM |
