Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 10-15-2018, 04:13 PM
abt abt is offline
Default Balancing OMNI hardware in/out
I have an HD OMNI. The analog in is set to -10dBV and the out is set to +10dBu (note dBV vs dBU). There’s a noticeable level drop between the signal going in and coming out of the analog paths.
Is there a good way of making the level balanced? Or do you just adjust the level using fader/plugin level adjustment? I find that no matter what I do it just doesn't seem to match.
Old 10-15-2018, 04:21 PM
Default Re: Balancing OMNI hardware in/out
What are you trying to do exactly? You using a hardware insert. What device?
Why is this important?
Old 10-15-2018, 06:10 PM
BScout BScout is offline
+24dBu output (line level)
+4dBu input
You should mention the gear you are putting as the insert.
how to get 4 x hardware inserts with AVID OMNI / PT HD outoftune Pro Tools HDX & HD Native Systems (Mac) 7 04-04-2014 08:53 AM
HDN Thunderbolt/OMNI, software without hardware P_J Pro Tools HDX & HD Native Systems (Mac) 1 06-01-2013 01:30 AM
how to setup hardware compressor and eq to HD OMNI CDac Pro Tools HDX & HD Native Systems (Win) 3 07-03-2012 06:58 PM
Support ? OMNI Hardware insert ADC question K Roche Pro Tools HDX & HD Native Systems (Mac) 4 04-02-2011 11:50 AM
OMNI ADC and Hardware insert question K Roche Pro Tools HDX & HD Native Systems (Mac) 4 03-06-2011 05:21 AM
