Old 05-13-2019, 06:10 AM
rmccam rmccam is offline
Default Re: D-Command quick assign default eq/dynamics
Originally Posted by ProtoolsLover View Post
You should be able to, PM me with your email and I’ll try it that way.
I just requested access as well. I'm sure my email is pretty obvious. Thanks!
Ryan McCambridge
Producer • Sound Designer • Mixer
Old 05-14-2019, 02:23 AM
elicious elicious is offline
Speaking for myself, I often find a better workflow is to custom map to the faders.
You can get there with in a button push or two
depending on if you have already viewed that plug-in during your session or not.
There are some odd glitches sometimes in the dedicated sections; certain params missing, etc.
Also, on many plug-ins, you can achieve finer resolution from the faders than you can from the dedicated knobs,
which often feel and act more like stepped attenuators.
For instance if you wanted to dial in exactly 3 DB on a parameter,
odds are you can often achieve that with the fader but not with the knob.
Other times with the knob I'll be turning a very small resolution and not hearing any change,
but mapped to the faders I can hear smaller increments.
Still, horses for courses when talking EQ’s or compressors,
but the real power of mapping to the custom faders is for dense plugs like reverb's.
The only disadvantage you cannot map multiple pages to them.
A little confusing, is that there are two ways to achieve that mapping.
You can go through the learn function that all plug-ins offer on their GUI.
But faster, and easier is to just hit the plug-in button on the custom fader section, then the map button,
then you can quickly map by hitting the select switch on the Channel fader and then tapping the parameter.
You can also export these maps from the surface of the D command and take these to a different studio.
On a smaller note, if you don’t have the Brent Heber vids,
I could post those to my dropbox, you might find them useful.
On a smaller, smaller note I just disassembled an extra D command ES fader pack I didn't need
and will be putting up the parts for sale,
for example faders and power supplies.
Have fun with it!
e
For the record studios
ihatetyping
Old 05-14-2019, 04:25 AM
Thanks elicious. So if you only have 8 faders, does that mean you can only custom map over those 8 channel strips, not additional banks?
I’m going to DM for that video. That’d be really helpful. Thank you.
Ryan McCambridge
Old 05-14-2019, 04:45 AM
You can custom map up to the total number of channels in your Dcommand system.
Under your operations prefs are selections for cf"type".
Also, you can map switches to the mutes in CF mode...
ihatetyping
Assign Pause & key command to soft keys? mikekiraly1 Artist Series 2 02-03-2012 10:29 AM
Default Eq and Dynamics zeeman Pro Tools TDM Systems (Mac) 5 07-15-2010 04:59 PM
D-Command assign multiple outs? macaholic ICON & C|24 2 03-17-2009 06:55 AM
7.2-User-definable default EQ & Dynamics question PMoshay Pro Tools TDM Systems (Mac) 4 08-03-2006 11:50 AM
EQ and dynamics panels on D-command MikeJaxx ICON & C|24 6 08-22-2005 07:35 AM
