Pro Tools First Install Issue
I'm new to Avid\Pro Tools, but I downloaded Pro Tools First and installed it on my Surface Pro 4. When I started the program, nothing happened. I tried uninstalling and re-install, and the same thing. Is it compatible with the Surface, or am I missing something?
Re: Pro Tools First Install Issue
So I'm guessing when you say nothing happened that you didn't even get the splash screen; is this correct?
Do you see PT in Task Manager when you attempt to start it? Can you try running PT as Administrator when you launch it? |
Have you registered at ilok.com and downloaded the ilok license manager and made sure you are connected to internet at all tiles as PTFirst need an internet connection to work and the steps I posted too.
In Windows I had to uninstall PTF 2019.6 then I installed PTF 2019.5 rebooted and then installed PTF 2019.6 rebooted and then it loaded just fine. Hope this helps.
Pro Tools 12.8 Install Issue | tubby1kanobee | Pro Tools 12 | 1 | 08-23-2017 11:45 AM |
Pro Tools First Install Issue | 08BlueSky | Getting Started | 2 | 02-10-2017 01:07 PM |
Pro tools 10 install issue | Ianchan03 | Pro Tools 10 | 3 | 07-09-2013 09:14 PM |
Pro Tools 10 install issue (HD Driver x64 missing) ? | ionactive | Pro Tools 10 | 2 | 01-04-2013 01:55 PM |
Pro Tools 8 LE Re-Install Issue | ibmarc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-04-2012 07:44 PM |
