Old 09-15-2019, 11:58 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Pro Tools version for older MacBook Pro
Originally Posted by Darryl Ramm View Post
And where do you put the video?... likely why you want a SATA III boot drive and *try* putting it there.
Don't worry about it too much -- one video file is less demanding for a slow hard drive than a dozen audio files. You need HD/Ultimate for multiple video files in a session.
Janne
Old 09-15-2019, 12:12 PM
I would not want to be running one video file on a 4,800 rpm boot drive. And is that drive even large enough? If I *had* to keep this model I would put put the video on a SATA III boot SSD... so size that purchase appropriately. If I could find a reasonable SATA *II* SSD then I'd use that as a second internal audio drive, otherwise sure I'd do the external Firewire 800 7,200 rpm audio drive.
I don't see a scenario where this computer is unlikely to be opened up and messed with.
Old 09-15-2019, 12:21 PM
JFreak's Avatar
Of course that video file would be streamed from the external session drive, in case the internal is a slow spinner.
But you have a fair point in replacing the internal drive. Together a 8GB memory upgrade and a 250GB SSD is less than a hundred and will make the laptop more than a hundred more valuable after the upgrade. And you can get up to 2TB internal drive if you need to, and don't need to sacrifice the DVD
Janne
Setup detected older version of Pro Tools DJ-Spol Pro Tools 12 8 02-11-2017 03:33 PM
Pro tools conflict with older version on 2nd HD julianlede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2009 02:09 PM
Which version of Pro Tools LE 7 is best for my older Mac G4 MIC FIEND 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-23-2008 10:43 AM
"older version of Pro Tools" error HearInc Pro Tools TDM Systems (Mac) 7 08-18-2008 11:11 AM
Older version of Pro tools harpdog123 General Discussion 7 07-25-2001 09:58 AM
