Old 12-16-2015, 06:12 PM
Chief Technician's Avatar
Arrow Re: Import audio error message
Originally Posted by auragami View Post
Could not complete the Import Audio command because Assertion in "/Volumes/Development/153787/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559.
I'm on a 2015 Macbook Pro, El Capitan 10.11.2, running PT 11.3.2
Use drag-and-drop instead of the Import command. It is unlikely that Avid will fix this for PT v11.3.x.
Old 01-30-2016, 05:25 AM
riccardotronca riccardotronca is offline
Default Re: Importing Audio issues
I have the same issue on PT 11.3 OS X El Capitan using the import command, and I understand it is a problem of compatibility.
If I try drag-dropping the .wav file from a folder (like some forum users reported to be working) PT loads the audio clip inside the track but with no waveform and no sound coming from it.
Any chance to solve this? Any chance an update on PT 11 will solve the compatibility issues with El Capitan?
Old 01-30-2016, 06:29 AM
Blind Danny Johnson Blind Danny Johnson is offline
Default Problem Importing Audio. Help Please?
First time I've ever had this issue and don't know where to start solving it. Here's the error message I'm getting:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559.
Any help would be much appreciated.
Thanks.
Old 01-30-2016, 06:30 AM
Default Re: Problem Importing Audio. Help Please?
Ps I'm on ProTools 11.3.1 with a MAcBook Pro running El Capitan 10.11.1.
Thanks.
Old 01-30-2016, 09:41 AM
I'd start by downloading and running this:
http://duc.avid.com/showthread.php?t=340741
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
  #16
Old 02-01-2016, 09:56 AM
freewind1974 freewind1974 is offline
Default Re: Importing Audio issues - line 559 error on El Capitan
To those dragging and dropping audio - make sure you have "Automatically copy files on import" enabled under Preferences/Processing.
Not sure if "Convert copied files to session format" option may be of help for these issues.
  #17
Old 02-06-2016, 05:33 PM
djtsutton djtsutton is offline
Default Pro Tools 11 with Mac OS El Capitan
I have Pro Tools 11 and it's not compatible with Mac OS El Capitan. Is any one else having this issue?
  #18
Old 02-07-2016, 09:06 AM
Arrow Re: Pro Tools 11 with Mac OS El Capitan
Highlight - "Pro Tools 11 on Mac OS X 10.11 El Capitan…is not a supported operating system (and will not be qualified with PT11)."
  #19
Old 02-09-2016, 09:27 PM
MarkWorth MarkWorth is offline
Default Re: Pro Tools 11 with Mac OS El Capitan
I believe I have found another problem.. (import audio did not bother me..easy workaround)
http://duc.avid.com/showthread.php?t=377667
  #20
Old 02-17-2016, 11:11 AM
MasterMixHD MasterMixHD is offline
There's a work-around for that error. Simply drag audio into the window instead of using the import command.
(pretend that I went on a rant of how retarded it is that 11 won't be fixed to work with el cap)
Any ideas how to fix this error during audio import: Assertion... line 603. luism Pro Tools 12 3 03-15-2018 12:36 AM
Pro tools 9 assertion error cannot import any data blazinbk Windows 4 04-30-2012 07:52 PM
Can't Import Audio from QuickTime Video -- Assertion Error David Ziegler Pro Tools 9 28 09-18-2011 05:09 AM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 10:38 AM
