  #21
Old 12-30-2013, 11:48 PM
Intransit Intransit is offline
Default Massive delay bug with multi out VIs
I'm starting a thread that's attempting to be a bit more clear. I saw a couple others... I just updated to PT11.1.0 OSX10.8.5
I've seen people post this issue with Superior Drummer, Addictive Drums, I did my tests with Kontakt 5 and Battery 4.
Toneshed did his tests with Aux tracks, mine Instrument. So it's not track type specific. Any instrument/sound routed to a multi out to a separate track with plugins WILL NOT be in time.
Video that Toneshed made: https://www.youtube.com/watch?v=U3wGdbKhJyc
This issue becomes even more pronounced with high delay plugins. Waves UltraPitch Shift the delay was almost a quarter note. This issue effects everyone making music with multi output VIs. As a composer this makes PT11 useless.
Mac Pro 2012 12-Core 2.4GHz RAM 48GB
Native 2018.3 HD_OSX 10.12.3
  #22
Old 12-31-2013, 02:50 AM
surstromming surstromming is offline
Default Re: Massive delay bug with multi out VIs
A video that Toneshed made: https://www.youtube.com/watch?v=U3wGdbKhJyc
Yes I see this too on Windows 7 and PT 11.1.0.
I´ve found a workaround though.
If I "Disable plug-in delay" on all drum tracks but the one with the longest delay it plays in sync. (In Windows it´s left mouse+Ctrl+Win)
See screenshot 1.
https://www.dropbox.com/s/ma86mthhiv...in%20delay.jpg
Then you can even see that the tracks does compensate the delay as the "cmp" number changes from 0 to whatever delay there is on the track with the largest amount of delay.
Best regards,
Markus
Windows 10
Intel core i7 4790k, 16Gb ram
MacBook Pro Retina 13" late 2013 OSX 10.12
Intel Core i5 2,4 GHz 8GB
Pro Tools 2018.4
Eleven Rack + Expansion pack
RME Fireface UCX
  #23
Old 12-31-2013, 03:29 AM
This verifies what just hit me an hour ago. ADC is NOT working on tracks with inputs fed from multi output VIs. Other then the video issues PT11 is having I don't see any other bug that should be addressed sooner then this. My jaw is on the floor how something as big as ADC not working on multi output VIs made it in this release.
Thank you very much surstromming!
  #24
Old 12-31-2013, 05:39 AM
I realised after some more testing that the result in my earlier post is only true if you just have plugins that causes delay on one of the tracks in a multi-out configuration, or the exact same amount of delay on several tracks.
If you have tracks with different amount of delay it gets more complicated to work around.
Then you have to manually write a negative number in all the tracks that have delay that is less then the one that has the most.
The number you must write s the same number that you see in each track but negative (-) for it to play in sync.
I hope this can explain it better as it is hard to explain:
https://www.dropbox.com/s/ejf90ukyx3...%20testing.jpg
So this makes ADC not so automatic anymore when using multi-out instruments.
Hope some mod can have a look at this and pass it up to Avid?
If you need more info or a better explanation just let me know and I´ll try give it to you.
Best regards,
Markus
Windows 10
Pro Tools 2018.4
RME Fireface UCX
  #25
Old 12-31-2013, 08:34 AM
Southsidemusic's Avatar
Hi Guys
I will pass this thread to the Avid Team and see what they say. Will post back with an amswer as soon as I have one
HAPPY NEW YEAR Friends and Hope You Have A Great Start 2014
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
  #26
Old 12-31-2013, 08:43 AM
Originally Posted by Southsidemusic View Post
Hi Guys
Christopher
Thanks!
Happy New Year!
Regards,
Markus
Windows 10
Pro Tools 2018.4
RME Fireface UCX
  #27
Old 12-31-2013, 02:09 PM
Thanks very much Southsidemusic!
  #28
Old 12-31-2013, 02:16 PM
It works. But this is NOT right. I have a 100+ track template I'm working with at the moment. 75% is multi out VIs.
So I should just go write a matching - number in any track that has a smaller number then the highest delay of the shared Vi??? This is ridiculous. lol...
  #29
Old 01-03-2014, 05:57 AM
thedoctormd thedoctormd is offline
Default Re: Understanding delay compensation PT11
Are Win 7 & 8 users experiencing these problems with virtual instruments?
  #30
Old 01-03-2014, 09:31 AM
Yes. Here's a thread I started about what's going on. ADC is not working with multi out VIs in PT11.
http://duc.avid.com/showthread.php?p...53#post2116753
major PT11 delay compensation weirdness. frozenintime macOS 18 02-18-2015 06:38 AM
LE delay compensation plug ins nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2007 12:57 PM
Plug-in Delay Compensation Nard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 10-03-2006 06:18 PM
Plug-In Delay Compensation guitar131 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-31-2005 04:31 PM
Plug In Delay Compensation tj_davies Pro Tools TDM Systems (Mac) 7 09-29-2004 12:51 PM
