Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
  #21
Old 06-27-2013, 05:37 AM
deeepi deeepi is offline
Default Re: Win7 drivers for 002/003
Originally Posted by bcwiz View Post
Nevertheless the current drivers are NFG
what you mean by NFG?
  #22
Old 06-27-2013, 07:20 AM
bcwiz's Avatar
bcwiz bcwiz is offline
No Fu#@&%g Good
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
  #23
Old 06-27-2013, 07:25 AM
bcwiz's Avatar
I do not think that I have a firewire problem, and in any case if I would like to solve this problem.
when I was using windows xp 32bit with driver v7, the 003 was connected to the firewire on the motherboard (Via chipset) and everything worked well, especially not had the problems described above.
now use windows7 64bit, with the driver 8.0.4b (the only one that works to 80%) and 003 is connected to the new motherboard (always Via chipset firewire)
I do not think that using a PCI firewire card with texas instruments chipset for it to resolve the problems described the drivers, also because I believe that other people using a card texas instruments have the same problems.
Have you tried "legacy 1394 drivers"? That seems to work for me with 003R on JMicron chipset which is supposed to be a bad chipset.
Brian Campbell
  #24
Old 06-28-2013, 04:47 AM
Have you tried "legacy 1394 drivers"? That seems to work for me with 003R on JMicron chipset which is not supposed to be a bad chipset.
yes, I tried the driver "legacy" and not known differences with the other drivers (non-legacy and VIA driver).
however, to me the 003 works more or less well with the driver 8.0.4b, the 'only annoying problem is that the 003 sometimes freezes while using cubase, and i need to turn off and turn on the 003 or restart pc.
Has anyone gotten Win7 X64bit drivers to work on a Mbox2 USB? djgizmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 12-10-2012 05:31 PM
Cannot run drivers for 3 mini in win7 Drew6560 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-06-2011 09:51 PM
Most up to date ASIO drivers for Win7? session_8 Pro Tools 9 1 11-08-2010 10:09 AM
Standalone ASIO drivers for Win7 x64 kenzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-21-2009 07:57 AM
Help-confused drivers for win7 64 in the future? bokos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-13-2009 02:44 PM
