Old 02-09-2012, 02:59 AM
jrk87 jrk87 is offline
Default Mbox 3 Pro Standalone Headphone Volume
I am using my Mbox 3 Pro in standalone mode. I have the headphone out of my laptop going into Inputs 1-2, then Outputs 1-2 are going to my power amp and speakers. The problem I am having is that both of the headphone outputs on the front of the Mbox are tied to the master volume, making it impossible for me to listen to anything through headphones without the monitors playing as well. Changing modes or outputs does not work. Both headphone outputs A & B mimic whatever is going out of inputs 1 and 2. Is there any way to fix this within the Mbox, or do I need to resort to doing something like turning off my monitors any time I want to listen through only headphones?
Old 03-01-2012, 12:04 PM
DJKeys's Avatar
DJKeys DJKeys is online now
Default Re: Mbox 3 Pro Standalone Headphone Volume
You can change this in the MBox control panel. You can choose to have individual output pairs controlled by Master Volume.
iMAC 3.2GHz 6-core i7
250GB SSD (internal)
1TB SSD (external)
16GB RAM
OSX 10.14.5
PT 2019.6
Waves Gold/RenMaxx v10.1
iZotope Ozone 8
Focusrite Clarett 8Pre
Nord Stage 3
Nord Lead A1
DSI Mopho X4
Old 03-01-2012, 12:38 PM
serio serio is offline
This is true for when the Mbox Pro is running as an interface. Stand alone mode is different. jrk, you will have to add extra hardware to be able to listen to the headphones without having your speakers playing as well.
Does the power amp not have a volume control? If it did you could keep the Mbox turned up and just use the amp's volume control to turn your speakers up and down. If not, any type of attenuation device post Mbox, pre monitor amp, can serve as your monitor control, letting you keep the Mbox level up so that you can control your headphone level while lowering the monitors with the attenuation device.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 03-01-2012, 07:03 PM
GregV GregV is offline
Not an ideal fix, but I've got a power strip on my desk so I can turn on and off certain things that I don't always need/use.
My monitor speakers are connected to that strip so that when I want headphones only, or I'm tracking with a mic, I can just hit the button and shut them both off.
Again, pretty low-tech, but it works for me.
Low headphone volume on mbox 3 pro gregpetre FireWire and USB Audio Interfaces (Mac) 3 11-27-2013 07:01 PM
Headphone b volume low....Mbox 3 Pro Mahkyb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2012 08:31 PM
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-13-2012 12:34 AM
Low headphone volume MickFowler Pro Tools M-Powered (Win) 1 10-20-2010 11:48 AM
Headphone/Monitor Volume on Mbox 2 Mini idylldon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2007 10:18 PM
