Pro Tools LE 8 "quits unexpectedly" at launch, after reinstall, and database delete
My Pro Tools 8 LE keeps "unexpectedly quitting" before it can launch. It was working ok, until I installed BFD2. So I trashed all BFD2 files, and restarting but no dice. I have tried: uninstalling and reinstalling Pro Tools, deleting databases, volumes and preferences, replacing firewire cables, dragging plug-ins from the "plug-ins" folder to the "un-used plug-ins" folder, start up with and with out external hard drive attached, running PT directly to comp, restarting, rebooting, etc. None of the suggestions I have read on other threads are working so far.. any suggestions are most welcome! details: Mac OS X Version 10.5.8 Processor: 2.26 GHz Intel Core 2 Duo Memory: 4 GB 1067 MHz DDR3 Avail space on HD: ~ 74 GB Pro Tools 8 LE Digi 002 Using 6ft Firewire 400 to 800 cable to connect Using 500 GB Lacie external Hard drive for recording and play back, through USB port mainly. But I've also tried daisy chaining PT through the Lacie drive. |
Re: Pro Tools LE 8 "quits unexpectedly" at launch, after reinstall, and database dele
How far into the launch sequence is it getting before it quits unexpectedly?
It doesn't get anywhere. The first thing I see is the window saying "the application Pro tools LE quit unexpectedly"
You didn't mention if you tried uninstalling BFD2 to see if that solves your issue
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
Yes, that was the first thing I tried. I mentioned it in the first paragraph.
Did you ever have a version other than LE 8 installed on this system?
No, not on this computer.
Do you get a "report" button after the unexpected quit? Could you please post the report somewhere in the cloud (i.e. DropBox) so we can view it and maybe determine what is going on?
Ok, I posted the report as a PDF file in the attachments section. thanks
The last bits of code that are executed before the crash are Apple's code. The last bit of Avid code that is executed before the Apple code is Sys_ThrowIfOSErr. I am not a developer. I think that code means Pro Tools is finding some sort of OS error and trying to display an error message. Instead, Pro Tools is quitting. Avid obfuscated exactly what is going on with their code, which doesn't surprise me.
Do you get any different results if the 002 is disconnected? I know Pro Tools will not work without the 002. I am interested in knowing if the unexpected quit still happens.
Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins! | dbC4G | macOS | 6 | 04-06-2012 05:51 AM |
Pro tools quits unexpectedly "solution" | AdamArnold | Pro Tools TDM Systems (Mac) | 5 | 11-19-2010 09:20 PM |
Pro Tools le 6.0 (and 6.0.1) hangs on "setting up Midi"-- then unexpectedly quits | rdatman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2010 09:15 PM |
Pro Tools "quits unexpectedly" | silverstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2010 11:24 AM |
Protools instantly "unexpectedly quits" and wont open at all | travisdunsmuir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-19-2010 11:23 AM |
