Old 01-29-2007, 07:26 PM
cpaul cpaul is offline
Default Front end Latency issue w/ Pro tools on a PC
Dear Forum,
I need a little help. Being mainly a MAC guy and wanting to use Gigastudio and other PC base synth plugins, I bought a Dell Dimension 8400 to run these programs. The Dell is a 3.4 Gighz Intel model using Windows XP, 1 gig ram , 160 gig hard drive. I'm running pro tools 6.4 LE thru the original MBox. Synth Plugin's are all using rewire thru Pro Tools. As a MIDI controller I have my old Yamaha SY77 (A synth I dearly love) into a Midsport/USB box then into the DELL. I can get the SY77 to talk to ProTools using this setup but I am experiencing a latency issue where the delay in striking the keys causes any overdubs to be out of time with the previously recorded tracks. Can't figure it out. I will listen to playback and hit a note on the controller but there is a delay before it sounds in the cans. I have tried playing with the knobs on the front of the MBox to compensate ( the input playback knob) but am thinking there is something internal with the DELL or Pro-TOOLS to correct this issue. Any Suggestions?
thanks Chris
Old 01-29-2007, 07:36 PM
spkguitar's Avatar
Default Re: Front end Latency issue w/ Pro tools on a PC
You need to make sure you are using a low H/W Buffer setting for tracking.
Pro Tools 11 Digi 003 Low Latency Monitoring Issue dizzydiscs Pro Tools 11 11 12-29-2013 02:16 PM
Pro Tools 11 latency issue edavidmartinez Pro Tools 11 0 07-21-2013 09:11 PM
Pro Tools 10.3.0 latency issue !!! HELP Hovak macOS 6 10-23-2012 09:49 PM
Low Latency Monitoring Issue for Mbox 3rd Gen and Pro Tools 8.0.5 on Win 7 timmystrong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-14-2012 05:36 PM
Rec Drop in latency when using Logic Front end...Help Guys! BearClaw Pro Tools TDM Systems (Mac) 4 01-29-2001 05:26 AM
