Old 07-23-2011, 01:01 PM
D_Japan D_Japan is offline
Default Would this UPS (Uninterrupted Power Supply) protect and power my gear?
I have a MacPro with Dual 2.66 Xeons. Apparently it has a 1,000 Watt powersupply.
I also have powered speakers, my 003, and a couple audio processors that total 500 Watts
I don't really get the VA ratings of these UPS systems. Can anyone tell me if this one will do the job?
http://www.amazon.com/APC-SMT750-Sma...1449486&sr=1-1
And how do you know?
Old 07-24-2011, 08:53 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Would this UPS (Uninterrupted Power Supply) protect and power my gear?
A UPS wil last longer the more capacity it has. If you just need a few minutes of charge, a small unit will be fine, If you want it to run for an hour, you need a much bigger unit. Most units will have a chart showing the runtime vs. load.
At 500 watts, this unit will run for only five minutes and it can't take more than 500 watts. I'd get a bigger unit. At minimum, I'd get the SMT1000.
How do I know? I did a Google search.
http://www.apc.com/products/resource...e&list=SMT750;
Converting VA to Amps (voltage fixed)
The conversion of VA to Amps is governed by the equation Amps = VA·PF/Volts)
For example 12 VA·0.6/(12 volts) = 0.6 amp
Converting KVA to KW (Kilovolt-amps to Kilowatts)
The conversion of KVA to KW is governed by the equation KVA = KW/PF)
For example, if the power factor is 0.6
120 KVA·0.6 = 72 Kilowatts
Converting Watts to KVA (watts to kilovolt-amps)
The conversion of W to KVA is governed by the equation KVA=W/(1000*PF)
For example 1500W/(1000*0.83) = 1.8 kVA (assuming a power factor of 0.83)
F
Converting Amps to VA (voltage fixed)
The conversion of Amps to VA is governed by the equation VA = Amps · Volts/PF
For example 1 amp * 110 volts/0.6 = 183 VA
http://www.powerstream.com/VA-Watts.htm
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-24-2011, 09:19 AM
KMcK KMcK is offline
Or you could use the handy UPS product selector on APC's website. http://www.apc.com/tools/ups_selector/
Old 07-24-2011, 11:17 AM
KMcK, indeed I did use the handy APS product selector and this is the machine that it recommended for "best performance." However, I am a bit nervous looking at stats that don't aren't listed in a scientific unit that is readily understandable to me.
Also, Park, how about one equation that begins with "W=" that would answer my question?
_*_*_*_*_*_*_*_*_*_*_*_*_*_*__*_*_*__*_*_*_*___*_* _*_*_*_*_*_*_*
So after further research, apparently the manufactures use VA because it's technically more accurate than Watts given this power factor thing.
In short, you can use W and VA interchangeably.
The caveats
(1) a Mac Pro is overbuilt; capable of generating 1000 Watts, but typically drawing far less, say 500W.
(2) The power supply is inefficient, so there is a "power factor" PF that says: if a supply is only 80% efficient you will need 625W going in to get your 500W. However, most modern power supplies are around 95% efficient, due to http://bit.ly/oQVyb1 PF correction designs.
So, the caveats are small.
As for me, to be safe, I'm going to assume that it will be drawing 1000 Watts when the power goes out, and get the 1500 VA rated unit.
Old 07-24-2011, 04:23 PM
Here is a calculator to convert VA to watts. It's a 1:1 ratio. I thought most people knew that.
http://www.thecalculatorsite.com/conversions/power.php
The conversion for Watts to Volt Amperes assumes a purely resistive load and does not take into account any reactive power (VAr); therefore effectively unity power factor.
Park
What should be hooked up to UPS (Uninterrupted Power Supply) word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-27-2010 04:15 PM
Uninterrupted Power Supplies word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-14-2010 03:02 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
