CoreAudio With Logic Audio
Hello,
Anyone know a way of getting logic to see more than 8 I/O of my TDM system? I have my logic 7 setup using core audio but it is only seeing my 1st 192 interface. Can core audio only address one card/peripheral? Bit of a shame if I can only use 8 ins in Logic. If anyone has had any expperience of this I would be grateful to hear from you. Many Thanks jholmesuk |
Re: CoreAudio With Logic Audio
If you have a TDM system You should be using Logic in DAE mode to access full Digi feature set. Under CoreAudio you (I believe) are restricted to first interface only
Mark is correct, you are limited to 8 inputs/outputs only? with digi core audio! Running Dae as your audio engine is the only way to get more inputs/outputs! You can run DAE and DTDM (direct TDM) together which enables you to have use of both worlds! TDM plugs on DAE and logic plugs on DTDM, linked together with the ESB (emagic system bridge) this works great for new sessions! but not good for loading previous sessions or sessions from other logic users!! Chris
Guys,
Can't believe I overlooked that! Thanks for the memory jogging!! All is sweet now. Cheers |
No audio output in Logic with digi coreaudio | crizdee | Pro Tools TDM Systems (Mac) | 2 | 11-07-2005 01:04 AM |
Logic 7.1 and CoreAudio 6.9 - don't work | KHFohlert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-10-2005 12:43 PM |
002R Coreaudio with Logic Pro 6.4.2 | subreact | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-19-2005 03:38 AM |
HD2 192 Coreaudio problems with Logic 7 | quark | Pro Tools TDM Systems (Mac) | 0 | 11-10-2004 11:50 AM |
CoreAudio, 002 and Logic | jdandrea | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-13-2004 08:44 PM |
