Strange Graphic Bug in PT 10.3.6
Hi Guys,
Im trying to help a friend who's experiencing a graphic bug on his LE rig. It seems to be affecting drop down menus, and "mis-aligning" the edit screen. I recall seeing this a while back, but cant recall the cause or fix. This is a new occurrence since updating OS. Trashing prefs did not help. resizing track heights helped momentarily, as did saving and reopening. any help would be greatly appreciated. thanks! rig specs: IMac 27" mid 2011 20 gb ram 10.13.6 OS MBox Pro interface with most current driver PT 10.3.6
Best, Sean Sean McDonald Red Medicine Recording LLC Sofa King Music Services http://www.seanmcdonald.com |
Re: Strange Graphic Bug in PT 10.3.6
PT 10 is not supported on your OS, and while it usually does not mean "not working" in this case you are dead in the water if you use anything later than 10.9.5
Compatibility info here.
It's a well known thing, PT10 on Yosemity and up - graphics problem with menus, discussed here plenty all those years ago. You either roll back to 10.8 or .9, or you upgrade to a PT version that supports High Sierra.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Thanks.
yes, checked the compatibility list, was just hoping to limp through until I could get him set up with a current, compliant PT version. As other than the graphic bug, the sessions seemed fine. thanks guys!
Strange Wav Graphic 12.4 | Stys64 | Pro Tools 12 | 4 | 06-29-2017 05:00 AM |
Strange (graphic?) bug with PTHD10 | handklang | macOS | 2 | 01-10-2012 03:09 PM |
strange graphic on edit page | boynigel | macOS | 5 | 10-30-2011 06:21 AM |
Strange graphic anomalies in Protools 8.0.3 | czorro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-25-2010 03:42 AM |
Strange waveform graphic | steve0916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-13-2003 08:52 PM |
