Preferred Memory
Where do you make the changes in Preferred Memory, I've dug thru the book and can't seem to find where this is done... I'm trying to open a large session (it's a live record that's 18 tracks, 24 bit depth, 48 minutes each) and I need to bump up the PTLE and DAE memory allocations... I'm running a G4 450 w/768 RAM, 5.1 LE - Thanks for the help!
Rick |
Re: Preferred Memory
I do it like this:
Select the application you want to increase by hightlighting it (make sure it is closed and not open) and then press "control-I" This will open the information window. Select "Memory" on the pull down window. Then increase the memory in the LAST (bottom) box. From Didi: Make sure your memory setting are as follows. Pro Tools preferred memory should be set to @20,000-35,000k. DAE preferred memory should be set to @30,000-50,000. Pro Tools and DAE minimum memory setting should be left at its default. You can confirm this by entering a zero into the minimum field and pressing enter on the keyboard, this will default the minimum memory setting. DAE's playback buffer size (Finder/DAE/File Menu/Set Playback Buffer Size) should be set to #2 The Disk Cashe setting in the memory control panel (Apple Menu/Control Panel/Memory) should be set to 512k or lower.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
AAE's memory is running low. Please try to increase AAE's preferred size ? | Scruffy1012 | Getting Started | 20 | 08-17-2013 04:53 AM |
Preferred OS for PT 10.3.3? | Submersible | macOS | 4 | 02-06-2013 01:55 PM |
Change Preferred Memory For Pro Tools. | JohG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-13-2010 07:56 PM |
Preferred OS for pt5.2.1 | audiodesign | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-06-2002 04:58 AM |
Preferred Interface | devapro | Tips & Tricks | 3 | 04-26-2002 01:13 PM |
