Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 06-27-2019, 12:28 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: DADman and Mojave?
Originally Posted by creativecontrol View Post
Greetings. Mac, Windows and the required flash firmware file should be available shortly. I’m checking internally now. Stand by...
Jeff
Are you putting together a system with DigiLink cards?
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 06-27-2019, 01:01 PM
BScout BScout is offline
Jeff
Yes. Will do on 2 MTRX but I still have a ship date of July 2 for those cards arriving in LA.
(Firmware flash is showing, only Windows version missing of DADman)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-27-2019, 01:52 PM
Who is the reseller you are purchasing from? This initial release for the DigiLink card support is Mac only. Windows support won’t be till August. Please feel free to message me directly.
Jeff
Jeff Komar
Old 06-30-2019, 04:21 AM
Artis Artis is offline
Hi Jeff!
Do i am required to upgrade MTRX firmware together with 5.3.3 ?
I see them in my account but fortunately, no manual states clearly that I SHOULD or SHOULD NOT upgrade firmware together with software.
I remember once trying upgrade firmware 2.2.0.1 with 5.3.1 and it always stuck in middle and made MTRX unbootable. So i had to use recovery mode to downgrade firmware. My conclusion then was that firmware upgrade is needed when installing Dante / SPQ / DigiLink modules. Am I right?
Old 06-30-2019, 06:55 AM
Greetings,
DADman version 5.3.3 adds support for Mojave in addition to the DigiLink expansion card plus a few other features and fixes. The DigiLink expansion card requires that you update your firmware to v2.3.0.1 which should be sitting firmly in your Avid account now.
A few other firmware considerations:
Any MTRX unit with version 2.1 or higher can be upgraded to the latest firmware. Any MTRX unit with 2.0 or lower needs to be upgraded to version 2.1 first, rebooted, and then upgraded to the latest firmware.
So - if you won't be adding a DigiLink expansion card you are not required to upgrade to the new firmware. There is another added benefit to the firmware update however. Users can now store unique names for expansion cards directly in the hardware. If, for example, you have multiple MADI and Dante (Brooklyn II + Dante 128 expansion cards) in your MTRX it can be challenging to know which cards are being used for which purposes. Now additional fields in the Configuration tab at the bottom of DADman allow you to individually label all of the various IO expansion cards added to your system. These labels require both the updated DADman version as well as the new firmware as the names are stored in the physical hardware device. Hope this helps.
best,
Jeff
Jeff Komar
  #16
Old 06-30-2019, 07:25 AM
Thanks a lot Jeff! That cleared things for me.
Mojave breaks DADman software Johnny Hulst Pro Tools HDX & HD Native Systems (Mac) 41 07-31-2019 08:23 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
DADman/PROmon on MTRX with OSX above 10.12 Sierra paulo m Pro Tools HDX & HD Native Systems (Mac) 4 03-01-2019 04:05 PM
MTRX Reference (Ref) Button in DADman Software jb_trm Pro Tools HDX & HD Native Systems (Mac) 4 02-20-2019 06:53 PM
Sum and Intercancel between MTRX DADman and S6 laki Pro Tools | S6 1 12-27-2017 04:18 PM
