Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 05-09-2019, 11:01 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default New Software Release S6 Version 19.5.1
UPDATE: v19.5.1 is now in your accounts with a couple of bug fixes and an improved Fader timeout preference. Whats New in 19.5.1
V19.5.0 is now in your Avid accounts.
  • Scroll to Track and Scroll Into View banks Controllers
  • New Attention methods from Pro Tools (replaces Attention on Select)
  • Options to Attention from clicking on different areas of PT (Track Name, Fader, Plugin, Pan, Send, Edit Window etc.)
  • Option to display the function/knobs from what was clicked on in Pro Tools
  • Option to then open that Functions Window in Pro Tools.
  • Pan and Send Windows now open in addition to Plugin Windows when selected from the Surface
  • Option to open these Windows from function button press or knob touch
  • Improved Momentary Fader Value options, added fall back to name whilst touching
  • New Pro Tools Softkey – Insertion Follow Playback
  • Independent DAW Solo mode selection
  • Func Switch on Process Module enables Plugin automation
  • Layout Banking Position Recall options – when does the system remember where you were last banked
  • KVM improvements
  • Performance improvements inc Session close times
  • Support for Think Logical Ethernet KVM’s
  • Dual monitor KVM support
  • Naming KVM sources and destinations
  • GPIO improvements
  • Control GPOs from Softkeys and fire Softkeys from GPI’s
  • Fader Start – Control 1, 8 or all faders from a GPI
  • New Option to load all knobs on Session load to improve All mode. (note does increase session load times)
  • New Softkey Appset for Pro Tools
EUCON 19.5 on Avids Blog
If you are currently on v3.5 and higher and on an active support contract, all you need to do is install the software, no activation needed.
In order to install the v19.5 software update, you will need your S6 console to be on a current Avid Support Plan. Your console came with 1 year of Avid Advantage ExpertPlus support with Hardware Coverage so please check your support plan expiration date. There are several options for renewing coverage (even if your plan has recently expired). If you are a registered owner, you will receive an email with details or you can contact Avid directly to hear about your options at : 1-650-218-4058
New Software Release EuControl Version 19.5.1 EddieJones Artist Series 16 08-08-2019 06:17 AM
New Software Release S6 Version 18.3 EddieJones Pro Tools | S6 8 01-14-2019 04:42 AM
New Software Release EuControl Version 18.3 EddieJones Pro Tools | S3 28 10-30-2018 09:04 AM
New Software Release S6 Version 3.7.0 EddieJones Pro Tools | S6 9 11-02-2017 08:24 AM
New Software Release EuControl Version 3.7.0 EddieJones Pro Tools | S3 0 10-19-2017 12:07 PM
