Old 10-07-2018, 12:03 PM
MusicMadness MusicMadness is offline
Default Command8 faders
Hi guys, I have a feeling that my faders are working louder than they suppose to. I bought this unit used and it's my first hardware controller ever and so initially I wasn't sure how loud should they work but comparing to some youtube videos I they actually are, especially in initial phase of movement. Besides, pressing Opt/Alt + touch affects setting channel level to +0.2 instead of 0. It's. not a big difference but I wonder is there anything I can do with it?
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Old 10-07-2018, 07:24 PM
Default Re: Command8 faders
Run the fader calibration routine? Google the web for a manual to explain how to do this. If you have automation that jumps up/down a lot, it could be normal mechanical noise
Old 10-07-2018, 07:58 PM
Ok, here's what fader test shows:
Lower position:
Fader 1: T=141; 0
Fader 2: T=144; 0
Fader 3: T=142; 0
Fader 4: T=141; 0
Fader 5: T=140; 0
Fader 6: T=142; 0
Fader 7: T=142; 0
Fader 8: T=142; 0
Middle position:
Fader 1: T=142; 509
Fader 2: T=144; 508/509
Fader 3: T=142; 509
Fader 4: T=142; 507/508
Fader 5: T=141; 510/511
Fader 6: T=143; 509/510
Fader 7: T=142; 509/510
Fader 8: T=142; 509/510
Upper position:
Fader 1: T=142; 1023
Fader 2: T=144; 1023
Fader 3: T=142; 1023
Fader 4: T=142; 1023
Fader 5: T=141; 1023
Fader 6: T=142; 1023
Fader 7: T=142; 1023
Fader 8: T=142; 1023
As I understand values 0-1023 represent fader's position but what is T parameter?
Old 10-08-2018, 07:08 AM
Neil H Neil H is offline
If you go so far as deciding to clean them I've made some video guides that you may find useful.
https://www.youtube.com/playlist?lis...7W48NrFPQyMU5q
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 10-10-2018, 07:09 AM
Many thanks, Neil. That might help
Old 10-19-2018, 05:22 AM
Unfortunately, looks like it's more like software issue rather than mechanic. I cleaned 4 faders and still all 8 behave the same way as before. Any other ideas please?
Old 10-19-2018, 09:37 AM
YYR123's Avatar
YYR123 YYR123 is offline
When I got my C|8 I was surprised how loud the faders were when they moved too.
Nothing was wrong but when I made steep cuts to automation they do slam around quite a bit
My Icon does the same thing but not quite as loud - I think avid should put some kind of soft stop mechanism for faders so that these types of sounds are minimized.
Daniel
Old 10-22-2018, 07:55 AM
post a video of whats actually happening.
Windows 10 Pro
Old 10-24-2018, 01:01 PM
no problem!
https://youtu.be/58Zbaef-otM
Old 10-25-2018, 03:05 AM
Yeah looks like a software issue to me, if you've done the calibration routine and its still the same i doubt there will be much more you can do.
Windows 10 Pro
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
Command8 Control 24 faders question Dot Pro Tools 9 4 09-28-2011 06:20 PM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 06:44 PM
Command8 Faders don't follow MIDI track automation highcard ProControl, Control|24, Command|8 1 12-19-2006 11:34 AM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
