Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 06-30-2017, 08:39 AM
Ruprecht Ruprecht is offline
Default Clips list is missing in ProTools First 12.8.0
Hi everyone,
most recently I updated my PT First from 12.3.1 to 12.8.0.
Since then I can't find the clips list any more.
Even the arrow in the right low corner is gone..
I desperately are seeking for a solution as I can't reach my clips anymore, so if anyone of you have a clue how to fix this issue, I will be very grateful.
Thanks Ruprecht
Old 06-30-2017, 10:24 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Default Re: Clips list is missing in ProTools First 12.8.0
I posted already with a list of features that disappeared form PTF 12.8.
I have no idea why they removed the Clip List. This must be a bug or oversight or something.
As you experienced, how do you suppose to access your Clips? Once you removed them from the Track
Edgar Rothermich
Author of "Pro Tools | First 12 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 07-02-2017, 10:59 PM
Turns out, Avid removed the Clip List on purpose, which is even worse then a bug. This is what it says in the Release Notes
"Restored the Tracks List, removed the Clips List"
BTW, I posted an article on the Pro-Tools-Expert website, explaining all the features that got removed:
http://www.pro-tools-expert.com/home...-recent-update
Edgar Rothermich
Old 07-03-2017, 03:51 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
That indeed is really weird. I was about to advocate this version to my students, since finally they'll be able to setup a session and work with that in my studio. The missing clip-list indeed is an show-stopper....
Arno Peeters
Tape TV Productions
Old 07-03-2017, 03:58 AM
Sardi Sardi is offline
I just can't understand how you can work in a DAW without a clip bin. Seriously.
Are you supposed to just keep EVERY edit of EVERY piece of audio on a spare track in case you want to use it?
I'm truly baffled.
Old 07-03-2017, 10:37 AM
tope d's Avatar
tope d tope d is offline
I'm truly baffled.
Hey Sardi,
Recorded and imported clips are still saved and can be accessed by right clicking on the clip on the track and then hover to "Matching Alternates".
Hope this helps
www.topedomingo.com
https://www.youtube.com/watch?v=JpOvCffHjws
Old 07-03-2017, 04:35 PM
I don't use PT First, so it doesn't directly apply to me.
I'm curious though. Unless I didn't understand correctly, your description sounds like you're referring to whole clips. What about edits of those clips?
Old 07-04-2017, 09:43 AM
The Pro Tools First app doesn't show any Clips that are not on any Track Lane.
The Workspace Window only only shows the audio files used in that Project, which are technically Whole-file Clips
Edgar Rothermich
Old 07-04-2017, 06:35 PM
Really? I did not know that.
Man that sounds VERY limiting. Glad I never recommended it to anyone.
Old 07-19-2017, 08:06 PM
meshane meshane is offline
This is insane.
PT10 - Clip List always empty (no clips show) quangaroo macOS 6 04-19-2019 07:52 AM
Missing the option to Remove or Delete Clips from Clip List - PT 10 xesands Pro Tools 10 1 02-04-2017 04:49 PM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
sorting clips in clip list martthie_08 Pro Tools 10 0 07-01-2013 03:59 PM
Protools LE 7.3 - Reason/TRacks/etc - missing in plugin list scalhoun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-06-2007 08:13 AM
