Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 08-22-2016, 08:15 AM
AVIDIVA AVIDIVA is offline
Default Re: [SOLVED] Pro Tools First: AAE error -6117 loop, Windows
I don't use Asio4All...I use MOTU gear which runs perfect with everything else. I get this error but cannot get out of the loop. Nothing seems to be working. I'm trying to run PTF.
Old 08-22-2016, 09:03 AM
810 810 is offline
I did solve my problems but not by using windows audio in the playback engine.
Rather I used the asio4all engine and simply set its panel inside hardware (under setup tab) to my realteks instead of the spdif AND inside the windows speaker icon in the tray (bottom right by default) right click that speaker icon there and use the playback devices option of the popup, set default playback device to the spdifs. Now the Realteks won't be tied up by windows and will be the default option for output if you start a session with output set to stereo output.
Made a video detailing this:
Asio4All Pro Tools 12 in Win 10 thru onboard spea…: http://youtu.be/deiKagRPCEc
Sent from my HTC One using Tapatalk
Old 09-01-2016, 01:03 AM
I solved my problem by uninstalling PTF. Now I have no problem.
Old 12-28-2016, 08:25 AM
Flutesamurai Flutesamurai is offline
Dude...it worked! Technology is not always straightforward and easy to use, is it? Either way, kudos to you for posting this, and thank you.
Old 01-08-2017, 02:23 PM
LGOJerry LGOJerry is offline
I had downloaded Pro Tools First, installed, uninstalled, run repairs, tried everything I could think of (and was available in Avid support) for two straight days, and THEN found this thread.
It worked. That is to say, SO FAR it works. I was able to get past the AAE _6117 error and choose my Roland Quad Capture Audio Interface and Assign my Nektar (not in the Avid list) LX 61 as Midi/Interfaces. I don't know whether I have things set up sufficiently for me to actually use PT First as yet, but I have the screen with the tracks and ability to record, so I'm close to where I need to be. Thanks very much to the poster of the solution to this driver/audio problem.
BTW, I downloaded Pro Tools First because of the excellent instructional videos I found on Avid's site. I have Presonus Studio 1 v2, but I've never been able to figure out how to use it. The instructional info online jumps around and isn't clear enough, so I've given up on trying to use it. I will say that downloading/installing Presonus Studio 1 was incredibly easy! Avid should be so easy, but I needed to understand how to use the tool and Presonus just didn't have the instructions. Heck! I even bought a commercially available user guide and that only showed a few photos, not nearly enough to understand how to do anything. Perhaps now I can get my songs recorded. Thanks again to the poster for helping me to get past the AAE error issue.
  #16
Old 01-17-2017, 05:01 PM
mike081377 mike081377 is offline
Has anyone had a problem where they insert pro tools cd and iMac doesn't recognize it . Cause I don't know what to do from here can someone help please
  #17
Old 02-03-2017, 01:05 AM
USCTrojanMBA USCTrojanMBA is offline
Thank you!!! Solved my problem
  #18
Old 03-21-2017, 09:17 PM
Hisui Hisui is offline
It worked! It worked! It worked!!! Thank youuuuu!!!!:d:d:d
  #19
Old 04-09-2017, 04:42 AM
dave freeman dave freeman is offline
Default Re: Pro Tools First: AAE error -6117 loop, Windows [SOLVED]
THANK YOU for posting this! You solved my problem for me as well - I had to disable the recording AND playback devices.
  #20
Old 08-02-2018, 05:40 AM
jamor jamor is offline
helped me on pt hd 12.4 too, thanks a lot, i used it before with external sound card with no troubles, but now on plain comp i just could not get out of the error loop.
Pro Tools First error -6117 Olafthebard Pro Tools | First Discussion 26 05-07-2017 12:08 PM
help with error. dae: -6117 on pro tools first 12.3.1 guaraca9588 Pro Tools | First Discussion 3 11-15-2016 04:22 PM
Pro Tools First - AAE -6117 Error hp24 Pro Tools | First Discussion 13 03-07-2016 06:00 PM
Pro Tools First Error 6117 Muse0216 Getting Started 2 03-02-2016 08:56 AM
RME BABYFACE audio device could not be initialized aae error -6117 [SOLVED] roachbeatz Pro Tools 12 2 09-26-2015 11:20 AM
