Old 04-13-2011, 07:53 AM
Akcrumposer Akcrumposer is offline
Location: 47 north central avenue apt 2k hartsdale ny 10530
Default M-audio BLUE SCREEN of DEATH!! Fixed!!
I just had this problem with my m-audio axiom 49. I had it for about a year and half and barely used it, upon turning it on last week I experienced the "BLUE SCREEN of DEATH". all my modes were locked and the null and bank button were lit and locked. I also tried re installing the enigma software to send it back to factory settings... Nothing. Even holding +\- down upon restarting it. So finally after numerous attempts and fails.. I decide to try one last thing. A new 12v power adapter and it WORKED!!! The screen came back and the keyboard reset itself. I hope this works for everyone else if they try. Cant promise anything but do try this. It may be a last resort instead of having to send you keyboard out and dealing with headaches. Im wondering if its caused buy power issues but goodluck to everyone with this problem
Old 05-01-2011, 02:51 AM
zedhed's Avatar
zedhed zedhed is offline
Default Re: M-audio BLUE SCREEN of DEATH!! Fixed!!
I have the same problem. I haven't tried a power supply yet, but upon checking it out I see that it's supposed to have a 9V DC 500mA Power Supply according to their website
http://www.m-audio.com/products/en_u...9VDC500mA.html
Do you think throwing in a few extra volts 'shocked' it into action?
Think I'll try the 9V first and see what happens.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 08-13-2012, 07:28 AM
Miser Miser is offline
I also got the blue screen and same exact symptoms but I did not have access to a 12v dc ps as I'm vacationing in nowhereville. It does seem like a power problem or from what I've read.... a chip. It seems confused in communicating with the host. So if you are reading this and are very upset that this has also happened to you and need it working again asap...... First try another usb cable. If that doesn't fix it.... Try turning it off and on 100 times if you have to. I think it took me about 300 or so in total or just removing the usb from the back. Try holding down on some pads/buttons at the same time as you do this until something appears on the screen. I did a - and + reset and eventually a 105 appeared. I switched usb ports several times trying to get it to react. I finally got it to where the usb not recognized dialog did not appear. I eventually got Studio One to recognize it. It started working again.... briefly, then back to the blue screen again. Turned it on and off and still a blue screen. I noticed the screen flickering a bit to. I shut down my Focusrite Pro 40 and the Axiom got going again. I guess the slight change in power affected it. I took me hours but its working again. It seems like it's sick/confused and gets a little better the more I use it. Just keep fking with it and it should eventually come back. I hope this helps someone.
Blue Screen of Death PT LE 8 MotifMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-21-2008 07:07 PM
Blue screen of death *S!@p&***!! dumdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-23-2007 11:16 AM
Blue Screen of Death dadio2002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-26-2004 08:31 AM
Blue Screen of Death + Huge Audio Files Kurp Digidesign Hardware & Software 0 03-22-2004 10:59 AM
Blue screen of death... Alex TCH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-06-2000 03:20 AM
