Re: Digi MIDI i/o Duplicated and greyed in Audio/Midi setup
Have you tried connecting the MIDI IO to a different port? I wonder if having all those devices attached is messing with USB communication somehow...have you tried it with all unnecessary devices disconnected? |
There is differently a problem with OS X 10.5.7 running alot of USB devices.
I would say take your OS back to 10.5.5 or 10.5.6 this will no doubt fix your other USB devices such as printer. Lets hope someone fixers the Digi Midi I/O |
The PSU does not help. I will try a different port and see if that helps. I will also unplug other USB devices as well. However, I have had this problem since I got this machine with Leopard. So it's not a new thing with OS recent updates. I have had no other USB issues at all. I believe that the problem occurs when I close apps that are using midi. At least it seems that way.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
Yes have gone one step furthere than trashing the preference.
I have put a new 500Gb drive in with a new stystem 10.5.5. and tried 10.5.6 as well. I only loaded the Pro Tools 8 plus the cs8.3 software and my 2 Midi I/O's nothing else on my Mac. I then went into AMS and sent my Midi I/O devices from scratch. Restarted my MacPro and there it was, 1 of my Midi I/O's in grey and a new one put in it's place with no of me midi devices on it. I own 2 Midi I/O's so I have been able to A B them. Nothing wrong with the devices and yes I have updated the firmware to version 2 in both Midi I/O's many times. I have also striped my Mac down so there is no USB devices or any thing else hanging off it except my HD cards and my 192's with my Sync I/O interfaces. I must piont out that I never had any trouble with my PowerMac running Pro Tools 7.4.x We have played enough games now so we need to have this problem escalated to the code writers or tech heads. Also I have a MOTU 128 express Midi device and it work every time. |
#16
Removing my other USB devices did not clear up the problem. I am currently testing different ports as I have many to test. No luck so far. I report back when I have tested all of them thoroughly.
#17
Ok. The story so fare 12/06/2009 8.34 pm Australia Time.
I have spend the day trying new things. 1) New Drive with a new OS X 10.5.5 and new install of Pro Tools 8 with cs8.0.3. 2) Rebuild my AMS Midi rig with 20 different Midi Devices. 3) Went into Pro Tools and made a new session with only one Midi track open nothing else no Audio tracks no Instrument tracks. 4) Selected each Midi device one by one using both my 2 Midi I/O's all good. 5) Tried open up various session and every time Pro Tools gets to the end of it's open up progress I lose one of the Midi I/O off line. 6) Made a new session and imported different session data from various sessions made in version 7.4 and version 8 with no Midi tracks in these session only Audio track. Then after the imports was complete bang go's the one of the Midi I/O off line. I am starting to think that Digidesign has not wrote the code for using two or more Midi I/O's in version 8. I know that Digidesign qualifies that you can run 4 of the Midi I/O's together. Maybe they forgot that part in version 8. |
#18
#19
Still having this problem, on a daily basis. PITA!!
#20
Audio MIDI setup says DIGI 002 midi device is offline | oliarnalds | MIDI | 17 | 10-23-2016 10:13 PM |
Remove a Greyed-Out Device in Midi Setup? | Reesho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2016 12:58 PM |
Midi IO not shown in AMS or is greyed out. When greyed out no MIDI options in Tools | drewsmith | Pro Tools TDM Systems (Mac) | 3 | 10-15-2011 06:21 PM |
Midi Regions / Losing the first midi note when duplicated | sad1robot | Pro Tools TDM Systems (Mac) | 8 | 02-10-2010 05:40 PM |
Can't see the Digi in the Audio/Midi setup | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-01-2003 08:27 PM |
