Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 12-21-2012, 12:00 AM
thisisblinky thisisblinky is offline
Default Pro Tools SE and MIDI Playback?
Hey guys, sorry to be a one post wonder but I've been searching the forum for hours and I don't have a solution yet.
I am having MIDI playback issues with Pro Tools SE, I downloaded the update which is supposed to be compatible with Lion and stuff. I can get audio from pro tools just fine and my mobile pre actually works pretty well, but when I try to play anything MIDI I get no sound at all. Not even the meters move in the pro tools window, I tried different tracks, different instruments, I tried just about everything and nothing works. Not even the MIDI on the demo tracks would play back.
I use MIDI with Reason and sometimes Finale and it works just fine there. I'm still pretty noobish with MIDI though so maybe I'm doing something wrong. Please help =)
Specs:
Macbook Pro OS X 10.8.2 Mountain Lion
2.53 GHz Intel Core 2 Duo
4 GB 1067 MHz DDR3
Pro Tools SE 8.0.3
M-Audio Mobile Pre
Last edited by thisisblinky; 12-21-2012 at 12:00 AM. Reason: computer specs and whatnot
Old 01-28-2013, 06:52 AM
ThanhLoan ThanhLoan is offline
Default Re: Pro Tools SE and MIDI Playback?
I had the same problem with imported MIDI file. I then had to assign MIDI channel to every track and it's OK now with me.
Old 01-29-2013, 10:31 AM
phylliserck phylliserck is offline
How do you assign MIDI channel to every track?
Phyllis in Montana
running SE w/ 8.0.3 patch
MacBook Pro w/Mountain Lion
Fast Track audio interface
Yamaha Modus midi keyboard
Old 04-11-2013, 02:17 AM
Tosio Tosio is offline
Hello. I have similar issue. I connect M-audio KeyStudio to my iMac and it's work in GarageBand, but not in PT SE. When i try to run PT i have this error:
But problem is i have in PT Optios my Keyboard:
Any idea?
Old 04-27-2013, 12:11 AM
crizdee's Avatar
crizdee crizdee is offline
Any idea?
I don't think the output "send to" should be routed to xpand2 1 exclusively! This means it's only going to be routed to this VI and not the rest of the midi. Maybe there's an option for All, or something not specific to one instrument!
Chris
Producer, Engineer,
www.ukmastering.com
Pro Tools 11 Playback of MIDI track mrvona macOS 29 12-14-2013 02:20 PM
Cant get midi to playback from Fantom XR in Pro tools! JTB Windows 1 08-22-2013 06:06 PM
Pro Tools 8 - MIDI Playback Problem ZiZO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-27-2012 06:27 AM
Pro Tools LE 7.0 - MIDI - Audio Playback abujji003 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-17-2011 05:55 AM
midi playback is not in time pro tools 9 shamanrock Windows 9 08-15-2011 07:48 PM
