Old 06-26-2012, 11:17 PM
RobinWinjil RobinWinjil is offline
Default fade tool disappeared from smart tool
I seem to have de-selected fades from my smart tool. How do I get it back? Thanks
Old 06-26-2012, 11:27 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: fade tool disappeared from smart tool
Make sure your regions/clips have handles and make sure that you're in the top corners of the regions/clips.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 06-24-2020, 11:14 PM
chrismeraz chrismeraz is offline
What does that mean "handles" on a clip?
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 06-25-2020, 12:09 AM
Ryan Young's Avatar
If you trim a whole clip, being able to trim it back out larger than the selection of the clip is the "handle" (the audio on the outsides of your edit boundaries). Therefore, if you're trying to create a fade on a whole clip, you'll only be able to fade into that clip, not outside its boundaries.
Please elaborate what you mean you de-selected fades from your smart tool? Your smart tool no longer allows you to fade a clip?
If you mean you can't fade "outward", it's a whole file.
If you mean you're not seeing a "fade tool" selected up top, there isn't one. The top toolbar will look like the attached picture. Your fade tool (within the smart tool) is automatically (smartly) activated when you go to a corner of a clip. The bottom corners will be crossfades, the top corners will be fade in/out.
File Type: png Screen Shot 2020-06-25 at 12.12.37 AM.png (19.4 KB, 0 views)
-Ryan Young
Additional Systems
Old 06-25-2020, 12:30 AM
Thanks for explaining Ryan.
There's some preference somewhere that's putting microscopic little fades at the beginning and end of every recorded clip, so that's why I couldn't use my fade tool. The solution for me is to just make a new trim selection and then make my fade with the smart tool.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 06-25-2020, 12:50 AM
Ryan Young's Avatar
OH!
There's a playback auto fade in but that shouldn't affect your clips. You must actually have tiny fade ins and outs on every clip. You can select all of your clips, click "Edit", "Fades", "Delete" and you have a clean slate. You can also select all of your clips, press CMD + F, and adjust existing fade in/crossfade/out shapes, slopes, and length.
Also, check in your PT preferences. If you're doing punch-style recordings, it might be auto-fading here. I have mine set to 0.
File Type: png Screen Shot 2020-06-25 at 12.52.37 AM.png (22.0 KB, 0 views)
-Ryan Young
Additional Systems
Different type of fade modifier while using the smart tool antonis Post - Surround - Video 4 05-12-2012 09:40 AM
Weird Smart Tool/Selector Tool issue? Marsdy Pro Tools TDM Systems (Mac) 11 01-15-2012 07:22 AM
Fade in volume on midi track with smart tool rockguitarist1255 Pro Tools 10 1 01-05-2012 04:36 PM
Smart tool fade doesn't work on some tracks ivfdad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-16-2009 06:03 PM
Trim-Fade with Smart Tool pfo Tips & Tricks 2 10-04-2007 01:49 AM
