Old 02-02-2018, 06:42 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Artist display turns blank after every single reboot
am I the only one getting this? After every single reboot both my artist mix and transport's displays turn blank. The button leds are working, the faders work, but there is no text on the displays. I have to 'restart eucon application' from the top menu bar (OSX) to get it back.
It's been like this since forever, OSX 10.8 to 10.12, with multiple eucon software and firmware versions. Also on several machines here in house.
All artists are running on the mac pro's dedicated ethernet port, self assigned ip.
Protools HD 12.8.3
Old 02-02-2018, 08:17 AM
Cheesehead Cheesehead is offline
Default Re: Artist display turns blank after every single reboot
Hi Farhoof,
I had this same problem.
There's a thread about ot on this board.
On mac we solved it by removing Eucon from 'system prefs/ users and groups/login items' rebooting without it and then re adding Eucon to login items.
Hope that works for you.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 02-03-2018, 05:35 PM
EddieJones's Avatar
Yes try disabling EuControl from auto start and see if that helps. If it does try adding it back using the new option right clicking on the EuControl notification icon up top.
Old 03-01-2018, 03:32 AM
Farhoof's Avatar
Thanks,
that seemed to have done the trick
Old 02-22-2020, 04:50 AM
XJENSEN XJENSEN is offline
This started happening for me as well after installing version 20.1.0.50.
Artist Mix scribble strip goes completely blank and requires EuControl restart.
Old 12-30-2021, 09:45 AM
msa14 msa14 is offline
I have not used my Artist Mix in awhile. Yesterday I found that everything is working - EXCEPT - the fader displays all are blank. Like the original poster here, the AVID logo lights up when powered on, and then the displays all go blank.
I was using eucontrol 19.7 and tried the fix here - namely, delete Eucon from the login items in users/groups (system prefs) and restart. It did not work despite multiple tries.
I reinstalled (successively) eucontrol 19.7, 19.9.1 and now 21.6. Nothing worked.
I did not find any other blank display threads that were relevant, much less as current as this.
Besides this issue, is there a cut-off past a particular eucontrol version that won't work with the Artist Mix and 2019.6 Pro Tools Standard (my version).
Thanks all
Old 12-30-2021, 10:04 AM
MSA 14 added system info (edits didn't take)
Pro Tools 2019.6 Standard - Artist Mix Eucon 19.7 (Eucon enabled in peripherals)
2018 Mac mini - 512GB - 32GB RAM
OS 10.14.6 Mojave
UAD Apollo Duo w/Thunderbolt + UAD Quad Satellite
Novation Launchkey 37 MKIII (HUI Slot #1 in peripherals) - never interfered
Main external drive - Sabrent XTRM-Q 1TB - PT sessions/audio & sound libraries
Old 12-31-2021, 10:29 AM
I know I'm late to the party since this started back in July 2021, but still not sure why it doesn't seem that anyone posted that EuControl 21.10.1 fixes this.
Happy downloading!
Old 01-25-2022, 08:24 PM
EddieJones's Avatar
These issues are caused by different version of OSX. Can you try EUCON 21.10.1 ?
Old 07-01-2022, 06:45 PM
j dub j dub is offline
I just hooked my artist mix up and the LCD screens at the top of the tracks do not show any information.
Any ideas?
Help...
I am on a MAC Pro 2013
OS 10.14.6
Pro Tools 2022.5.0
Eucon 'about" screen says:
Version 2020.11.1.10
Eucon Version 4.7.4.10
Counter display blank when opening session Armando ICON & C|24 2 03-06-2013 03:17 PM
Blank LCD Channel display jaman4fun VENUE Live Sound Systems 0 08-12-2012 03:27 PM
HELP! win 7 9.02 install and 003 display is blank TBaker Windows 11 04-10-2011 05:50 PM
!!! Setting display on imac from millions to thousands turns PT YELLOW !!! oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2010 04:02 PM
Help! 02 turns on, but display doesn't show text! cosmicevan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-22-2006 02:18 AM
