Old 06-03-2005, 06:50 AM
barkingdog barkingdog is offline
Default cracking open the c24 for repairs
I need to replace a switch on my c-24. The switch is the GO TO START button on the lower right just above the transport. What is the best way to get inside the c-24? is it from the front or the back? Digi sent the replacement part but no instructions. It appears to be an easy fix but I'm not sure the correct way to get into the unit. Any help would be appreciated.
Audioczar
Old 06-03-2005, 09:49 AM
DigiTechSupt's Avatar
Default Re: cracking open the c24 for repairs
Please contact Digi Tech Support and they will be able to provide repair manuals in PDF format.
Avid Audio Tech Support
Support FAQ
Old 10-09-2017, 07:53 AM
Synchrosphere Synchrosphere is offline
How can I contact the Digi Tech support
i can´t send a message to get the pdf Manual to open my C 24. I had to repair a fader ( locked by a part of a Fingernail
Old 10-09-2017, 09:30 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Hi Synchro ...
Is this the C|24 or the 'old' C24 ?
Old 10-12-2017, 12:15 AM
Hi Gemylon,
it is the new C|24
Old 10-12-2017, 05:05 AM
Gemylon's Avatar
Originally Posted by Synchrosphere View Post
Hi Gemylon,
it is the new C|24
I changed 2 cards in my C|24.
Did it myself. No repair manual.
And I am not a technician ...
Use a steady table to work with plenty of lights available.
Turn the C|24 over on a soft surface, and remove the bottom cover.
Plenty of screws yes ... but most of them are identical.
Take your time.
Once opened, everything is partly accessible.
Can't remember what the transport section looked like exactly,
but you probably have to remove stuff to get to the buttons.
Be patient, and use plenty of photos for documentation.
Don't trust your memory
So yes, it is possible to do it all by yourself without any manual.
Good luck !
Old 10-12-2017, 05:18 AM
Thank you and a good Idea
I will do it todays Evening and tell how it works
Regards from Berlin
Old 10-23-2017, 08:16 AM
Hi Gemylon
thanx for your help, every thing work fine and it was very easy to open it and change the fader
kindest regards from Berlin
Old 10-24-2017, 06:54 AM
Gemylon's Avatar
Hi Gemylon
Glad it worked out for you :)
All the best !
Robotic cracking and popping sound. fretcruiser Pro Tools Software (Win) 11 11-04-2012 02:05 PM
Popping and cracking using adat in (003r) geekkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-31-2010 04:12 PM
Cracking Noise During Playback openoyster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-26-2009 06:49 PM
Cracking and extreme noise in LE 7 atomicwave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-19-2007 02:48 PM
GETTING RID OF POPPING OR CRACKING NOISE coleslaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-24-2002 06:24 AM
