Old 09-04-2002, 02:36 PM
sonoma bass sonoma bass is offline
Default One band EQ?
I am not familiar...what does a one-band EQ do? How does it work? Thanks in advance.
Old 09-04-2002, 03:13 PM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
Default Re: One band EQ?
It's a "tone control", kind of like the "bass" "mid" or "treble" knobs you might find on a consumer stereo system.
One Band EQ can be used as:
Hi Shelf
Lo Shelf
Hi Pass
Lo Pass
Notch
Single band boot or cut
Choose the type of EQ you want from the graphical icon buttons near the top of the plug-in window.
For Shelving you set the frequency at which you want the shelving to start and then set the amount of boost or cut.
For Hi or Low Pass you just set the cutoff frequency.
For notching or single band boost or cut you choose the center frequency, the "Q" (or bandwidth) and the amount of boost or cut.
That's about it. Pretty simple to explain. More difficult to explain effective usage! [img]images/icons/wink.gif[/img]
Mike
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
Old 09-04-2002, 04:22 PM
Roy Howell Roy Howell is offline
Other than it's normal use, it also can be used to get the best 'transistor radio' or 'telephone' sound I've found, because you can control just how thin or thick you want it to sound, whether it be used on the Master Fader, or just one track. I think the Low Frequency button is the one that does it, and then just slide it's fader to what you want. It really is great for that.
rh music
Old 09-04-2002, 04:29 PM
The Caine The Caine is offline
I used it just yesterday for exactly that. The end of a song that fades to a solo vocal still riniging and the effect is very cool. I also have used it on my distorted slide parts to get that really gritty blues tone. [img]images/icons/smile.gif[/img]
I got an ant farm. Those fellas didn't grow jack - Mitch Hedberg, (slightly modified)
Old 09-04-2002, 04:56 PM
jeffinmarin jeffinmarin is offline
HEY. You play bass and live in sonoma co.huh? WOW, could I use you if you want to gig. What'cha think? JEFF
jeff
Old 09-04-2002, 05:47 PM
Stone Knife Stone Knife is offline
It's also excellent for extreme LO cut, to clean up low bass that is just breath noise and floor rumble (use the high pass setting)...
Old 09-05-2002, 07:34 AM
Jeff, I am moving to Sonoma soon (early next year), will be there at the end of the month to visit...you sure could use me when I get there. Why dont you email me at [email protected] and we can talk...
Old 09-05-2002, 08:24 AM
Haigbabe Haigbabe is offline
Greetings,
Did some recording recently where I had extraneous noise from the building used for recording. Located the frequency and notched it out.
Very useful. Can be used in AudioSuite mode for occasional filtering or automated for discretionary uses.
Try it.
Best regards,
Haigbabe
Drive fast, take chances
Old 09-05-2002, 09:08 AM
Ultraslide Ultraslide is offline
I also use the 1 band EQ to fix agregious phasing problems. Next to the input level control there is a phase-reverse button that is uber handy, and has almost no CPU overhead!
Weeeee!
the 'slide
[img]images/icons/grin.gif[/img]
Powermac G4 DP1.25 002R PTle 7.4
Powerbook G4 1.5 Mbox PTle 7.4
.band to PT frcjt macOS 3 05-19-2013 07:48 AM
EQ3 4 band Steve White Pro Tools TDM Systems (Mac) 1 07-23-2008 03:08 PM
what mic´s to get to mic a whole band hlynur Pro Tools TDM Systems (Mac) 6 12-10-2006 07:42 AM
OT - YOUR best band name(s) graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-20-2003 12:18 AM
Bussing of 1-band or 4-band EQ TonyR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-15-2002 01:02 PM
