PT Won't boot up due to FW Driver
This is a new one. For years now, my main MIDI controller has been my Yamaha Motif XS8 connected via FireWire to my PC. It all works fine. I've kept my Yamaha-Steinberg FW driver up to date over the years. Today, for no reason I can fathom, when I boot up Pro Tools, it goes through the usual initial boot up steps, scans for the plug ins etc, then a window pops up really quickly telling me it wants to install the Yamaha-Stienberg FW driver (something I've NEVER seen it do before ever!) and then come up pop-up window saying "Preparing to install"...and then it just sits there forever.
THe thing is the FW driver is installed and working. I can look at the screen for it separately and its there and recognized by the PC BEFORE I boot up PT. I tried booting up Reason 9.5 and had the same damn thing happen. I have no idea what is causing this. I've never seen it before in over 8 years of using PT with my Motif with FW. I uninstalled and reinstalled the FW driver. Same thing. Rebooted at least 3 times. Same thing. I have no idea what to look at. Win-10 64bit system. PT 12.8 Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: PT Won't boot up due to FW Driver
Do you have any other devices you could plug into the Firewire port to rule out the Firewire card as the problem? The fact that the problem is not limited to ProTools might indicate a hardware issue.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Same thing with both PT and Reason for both FW and USB. Its just bizzare and I have no explanation for it. My FW driver is the latest version 1.6.6...which hasn't been updated by Y-S since early 2017 I believe. Same for the USB driver. I've kept those up to date. Its like neither Reason nor PT wants to recognize the Y-S driver all of a sudden. I just don't know where to go from here. There's no way to bypass the screen to just get either PT or Reason to just boot up so I can check the settings in them. I can't figure it.
I tried using my Motif XS editor via the FW and it worked just fine. If the FW card were the issue, then the editor would not be talking to the Motif via the FW connection.
Could there be something amiss with the windows installer program? That's the window its stuck on. It says "Preparing to Install" and then just sits there with the blue wheel of death spinning in it. How would I check that? I'm completely at a loss on this one.
Well that's good that the Firewire card is OK. It sounds like a process is trying to install a driver over the driver you have already installed. I am way out of my element here, but I would look through all of the processes and services in Windows Task Manager and look for something that might be a device driver installer. If you see processes or services that you have no idea what they do, you can generally Google them and get a general idea of what they are.
It sounds like something maybe got corrupted during an update or a shutdown. Maybe even some sort of registry thing. Though I have had completely unrelated programs cause faults with midi through USB. Perhaps you can do a recovery to slightly before the issue started. Or maybe someone else has a less drastic option
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
First though...I need to swear, scream and throw a fit...
1-System restore back to when the old FW driver was in use. 2-Ask Yamaha for a link to the old driver and explain what happened(maybe you're not the only one with the issue). 3-Connect the keyboard via midi cables.
Perhaps there is an “easy fix” - by uninstalling then reinstalling the Yamaha Steinberg FW Driver V1.6.6 for Win (64-bit)
https://europe.yamaha.com/en/support...ver_win64.html
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
ASIO4ALL driver or audio interface driver for playback engine? | slidincharlie | Getting Started | 2 | 02-26-2017 12:31 PM |
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files | taylor4814 | Windows | 1 | 02-16-2012 05:54 PM |
Boot Camp - Dual Boot, Dual Versions of PT LE? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-17-2009 04:15 AM |
Bug in Digi Core Audio Driver? Driver update coming? | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2003 08:59 PM |
UNSUPPORTED DRIVER CALL, CHECK DRIVER VERSION | finalcut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-06-2003 10:51 PM |
