Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!!
Hello, first of all thank you for reading this thread!
I looked pretty much everywhere and I am starting to think my 11R could be defect... anyhow, hoping not! Problem: -No Eleven Rig L/R wet Signal in Cubase Current Setup: -Cubase 5,10 Build 105 -11R Driver 1.1.10 -Guitar in dry signal OK (11R Input > Guitar IN OK) -Headphone wet signal OK -Main Output Speaker wet signal OK -Output to amp to mixer wet signal OK Behavior: In cubase while recording, only the Guitar IN track gets an input signal. The track which has Eleven Rig L/R has an input to not have any signal coming in. Please have a look at the screenshots for detailed configurations. Will uninstall driver and reinstall. Also will try with different Cubase version then update this thread. Please Help asap. Thank you Best Regards Screenshot 7 pictures. http://imgur.com/YtWPPaO,F3AomRh,Xpd...DhPelS,USJ39w2 |
Re: Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!!
UPDATE SOLVED:
I finally made the test in a new project using a different Cubase version. Turns out that the problem was only this: I had so much tracks that I didn't realise that they we're on GLOBAL MUTE at the top of the track colum header. Just make sure that Global Mute is tested ON and OFF. Thank you Regards |
Eleven Rack no input | brutalzacjames | Eleven Rack | 2 | 07-07-2015 07:59 AM |
Please Help Me - Eleven Rack and Cubase | igiorgino | Eleven Rack | 1 | 04-16-2015 07:30 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack..True Z input, | PMcC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-28-2010 08:56 PM |
Eleven rack and cubase : monitoring problem | Holyoli | Eleven Rack | 1 | 10-10-2010 03:49 PM |
