Old 05-03-2000, 04:40 PM
Kickin.da.speaker Kickin.da.speaker is offline
Default SOLUTION! Digi001 midi ports with Cubase, DP or Logic!
The solution!
Go here, paste this: [from digidesign]
"With the initial release of Digi 001, both the Digi 001 MIDI ports and Digi 001 Output Drivers cannot use Direct I/O simultaneously.
This limitation is limited to third-party applications and the SampleCell Loop Editor- Pro Tools LE is unaffected by this problem.
To avoid this problem, customers wishing to use Digi 001's audio outputs with a Direct I/O compatible third party application should use an external MIDI interface instead of Digi 001's MIDI in/out connection."
as a 'problem description' and ask them to have it fixed! The more users asking, the better the chances of having it fixed!
David.
6am eternal
Old 05-04-2000, 02:49 PM
DigiTechSupt's Avatar
Default Re: SOLUTION! Digi001 midi ports with Cubase, DP or Logic!
ASIO drivers are written (and supplied) by sequencer companies (in this case, Emagic) to communicate with our hardware via code embedded within the DigiSystem INIT (DSI) system extension called Direct I/O. DSI 5.0 is the first version to include support for the Digi001. However, there is a problem with Direct I/O accessing the Digidesign Output Drivers and the Digi001 MIDI ports simultaneously. This incompatibility has been addressed and fixed in DSI 5.0.1 which will be available on our website as soon as Pro Tools 5.0.1 is released at: http://www.digidesign.com/serv/ftpmaps/daedsi.html. Thank you for your patience regarding this matter.
Brent
Avid Audio Tech Support
Support FAQ
Old 05-04-2000, 03:25 PM
lwilliam lwilliam is offline
Kickin...I saw your post yesterday and tried the midi port on the 001 with the new Cubase 4.1r2 - no go. As Brent (the man) suggests, I guess we'll have to wait a bit longer...as it's not a Cubase issue.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 05-04-2000, 04:45 PM
Alright!
Let's wait and see...
David.
6am eternal
Old 08-25-2000, 05:22 PM
Tommy the Z Tommy the Z is offline
I dug up this string and tried clicking the URL to see if DSI 5.0.1 is available ("this page does not exist") Is anyone out there working samplecell with 001 without an external MIDI interface??
Cubase SX v2.01 and Digi001= NO midi post2 linga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-11-2004 12:28 AM
Digi001 midi with cubase sx Woodwater 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-21-2003 04:50 PM
Cubase and DIGI001 MIDI go i huvet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-02-2002 02:57 AM
Anything to access just Digi001 MIDI ports in MacOS X? David Hempling 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-13-2002 11:02 PM
how come the digi001 midi ports dont show up in OMS on unsupported machine ccstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-08-2001 12:24 AM
