#21
Re: Axiom Pro comments?
If it's as easy as running the 8.04 installer and then the 8.1 agaion sure. Youa are very helpfulm but not Digi techsuport right?
best Janne A. |
#22
Hi Janne, no I'm not Avid Audio Support, I'm User Support.
Ummm... what I'm trying to narrow down is whether PT HD 8.1.0 is the stem of your issue. As this might be a bug regarding PT HD 8.1.0. But only further regression is going to prove otherwise. That is you might need to as the term goes, help us help you.
Aaron Mulqueen - 001 HD Native |
#23
Which model of the Axiom Pro do you have - the newer, second generation with DirectLink, or the older version? And is it the 25, 49 or 61 key model?
Can you tell me exactly how you have it configured in the Setup>Peripherals>MIDI Controllers window? |
#24
DTS, is there any mention of this being a Known Issue in the PT HD 8.1.0. Read Me?
#25
I sincerely hope it is a new one...as I bought it a few days ago...
It is th 61 key model and when I boot up it says: Mar 5 2009 V1.14-0082C K:01.01 P:OK! And yes, it is configured as per M-audio instructions and many functions do work as advertised. Incuding bankshift, insert and play/stop/rev faders, knobs in plugins etc... I tried downgrading to 8.04 but the problems where the same, so I now upgraded back to 8.1cs1 thanx! |
#26
Freak behavior, definitely, and not very common - but it has happened, which is why I asked. I guess I should have asked if there were any other devices setup in Peripherals. Can you test this from a new administrator account? That will help narrow down if the problem is specific to the user account or system-wide. Also, I'm not sure if you have access to another Pro Tools system, but testing it there will also help give us information about where the problem lies. It could be a defective keyboard, but it's difficult to say for sure yet. Have you tried a preset reset? Hold down + and - while powering the Axiom Pro on to restore the factory default presets and see if that changes anything. |
#27
DTS has a 2nd generation Axiom PRO been released? i have been looking around and find no mention.
#28
Hello,
I tried the reset of presets to no avail. I can try it on my LE system if hypercontrol works with LE. thanx Janne A. Quote:
#29
http://www.m-audio.com/index.php?do=...ardcontrollers |
#30
Ok, let us know what you find. We'll get this sorted one way or the other...
Axiom Pro 49 and Axiom 61, Prepheral issue? | udhoshi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-22-2011 03:45 PM |
Please, Comments about MD3/MD4 TDM | Alécio Costa | Pro Tools TDM Systems (Mac) | 2 | 02-12-2006 10:19 AM |
Comments? | edwardo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-03-2005 12:51 AM |
PT 5.0.1 comments | Compression Records | Pro Tools TDM Systems (Mac) | 4 | 06-27-2000 07:00 AM |
MC-505 and 001 any comments. | Christian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-05-2000 09:28 AM |
