Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-20-2019, 10:23 AM
hannahjazzz hannahjazzz is offline
Default Exporting session for another DAW
Hi there
I need some help with exporting my mix session.
I am using pro tools LE 8 and have a final mix that I want to export in .wav to tweak a little more on somebody else’s system.
I would like to know that for my individual tracks, how I can export everything without reverting back to the unmixed version. I.e. save all of the fx, EQ, etc... for each individual track.
If I consolidate the session and export in .wav will this save all of my work thus far?
Many thanks
Hannah.
Old 03-21-2019, 09:58 AM
Ben Jenssen's Avatar
Default Re: Exporting session for another DAW
Hi. I'll assume you're talking about "another DAW" meaning not PT. Then your simplest, if not easiest, way is to print (record each track to a new track) all the tracks from the exact same point in the timeline. Then you'll get an audio file for each track exactly like they sound now, plugins fx and all, that can be dropped into any DAW and line up perfectly timewise.
Say you have a track called Piano. Click on its output and select "New track...". Give the new track a name, e.g Piano.print, and rec enable it. Make a selection in the timeline that includes all of the piano audio, making shure the selection begins at a specific point that you can repeat on all the tracks. Maybe use a marker, maybe use just the beginning of the session, 0.00.00.
Record the piano to the new track.
Repeat with all tracks, also fx returns. Remember, you can do this with multiple tracks simultaneously.
Now, with PT8 I guess your session uses SDII files for audio, and you'll have to convert them to WAV, but that shouldn't be too difficult.
Old 03-21-2019, 01:09 PM
Hey thanks so much. I’ll definitely try this.
Exporting a session problem everettb21 Pro Tools Express on Windows 2 03-19-2018 01:06 AM
Exporting Session Help?? mprev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2009 04:08 PM
Trouble exporting session from pc to mac dcook Pro Tools M-Powered (Mac) 0 01-22-2006 01:59 PM
exporting tracks to another session badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-12-2004 10:52 AM
If I edit files after exporting to 2nd session, how is 1st session affected? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-02-2002 12:01 AM
