Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Buy & Sell
Old 03-29-2016, 01:26 AM
Dirk Reinking's Avatar
Dirk Reinking Dirk Reinking is offline
Default FS Aphex Aural Exciter and Big Bottom Pro Bundle
Give your tracks more presence and more bottom with these hugely popular AAX processing effects
The patented Aphex Aural Exciter has been used on thousands of hit albums, commercials, films, concerts, installed sound systems, and broadcast stations, increasing presence and restoring natural brightness and detail, almost magically and without significant equalization. Modeled after the Big Bottom circuit in the Aphex Model 104, Big Bottom works on bass frequencies and adds low-end presence and punch without increasing peak level. This allows you to pack more bass into your mix without overloading amps and recorders or blowing up speakers.
• AURAL EXCITER:
• Brings instruments and vocals up out of the mix
• Patented harmonic generation process increases bandwidth without increasing level
• Increases presence, clarity, speech intelligibility, and detail without significantly increasing peak output
• Total flexibility in tuning the Aural Exciter to your needs
• BIG BOTTOM PRO:
• Deeper, more resonant bass
• Little or no increase in peak output
• Tighter bass articulation and extended low frequencies
Additional Info: APHEX AURAL EXCITER •*Rotary control parameters: level, tune control (sets bandwidth of second-order high-;ass filter in sideahcin prior to harmonics generation; 700 Hz to 7 kHz), peaking, null fill (adjusts curve of the high-pass filter to fill in the null caused by the summing of the sidechain signal and the input signal), harmonics, timbre, mix. •*Switch controls: drive, density, “ax” (turns Aural Excitement process on or off while allowing audio to pass through DSP), solo APHEX BIG BOTTOM PRO • Rotary control parameters: level, tune, mix •*Switch controls: in/out, solo, phase, AutoTrace (auto-threshold function for compressor part of the chain), links, Left/Right
$150 please add iLok fee
cheers
d
Old 03-30-2016, 09:50 AM
jjnssn jjnssn is offline
Default Re: FS Aphex Aural Exciter and Big Bottom Pro Bundle
PM me.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 05-13-2016, 10:14 AM
sold
Aphex Aural Exciter and Big Bottom Pro AAX? Paph AAX Plug-ins 49 10-23-2013 12:56 PM
Aphex aphex big bottom pro/aural exciter bundle tdm rtas Tank Buy & Sell 0 06-10-2013 06:45 AM
Aphex Aural Exciter and Big Bottom Pro Bundle-same license for PT7.4 and PT 8 and 9 Straight Shooter Pro Tools TDM Systems (Mac) 1 05-11-2011 07:55 AM
Aphex Aural Exciter and Big Bottom Pro Bundle .??? Valeri Pro Tools TDM Systems (Mac) 2 10-12-2004 01:03 AM
Aphex Aural Exciter/Big Bottom Pro vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2002 01:23 AM
