Old 08-27-2009, 01:56 AM
bad jitter bad jitter is offline
Default Saving session copy and Altiverb IRs
When saving a session copy in another drive, is there any way to also export the Altiverb IRs used in session at the same time? Or is "manual" checking which were used, and copying them by hand the only option?
Old 08-27-2009, 03:15 AM
Default Re: Saving session copy and Altiverb IRs
The IRs are not part of the plug-in setting file so the session assumes that they are locally installed in AV´s IR folder.
frank.
PTHDn 2020.9 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 08-27-2009, 04:34 AM
Pete Gates Pete Gates is offline
TL Space Can embed IRs in the session file, I don't know any way to make Altiverb do that unfortunately.
Pete
Old 08-27-2009, 07:18 AM
That's a very good feature of TL Space. I have lots of automation (lots of IR changes) in my Altiverb track. Easiest option would maybe be to copy my entire IR folder (7GB) to the machine, where the session would be opened next time.
HTML code is On
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 04:42 AM
Saving a copy of a PT 8 session as PT 7? sodium glow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-22-2009 08:05 PM
-37 error when saving session copy SirLexelot Pro Tools TDM Systems (Mac) 3 03-25-2006 02:52 PM
Saving Session Copy files. new engineer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 10:29 AM
Saving a Copy of the Session Q Renie Pro Tools TDM Systems (Mac) 2 01-16-2002 02:51 PM
