Old 05-22-2009, 02:09 PM
sodium glow sodium glow is offline
Default Saving a copy of a PT 8 session as PT 7?
I need to save a PT 8 session as version 7. But I don't have that as an option from the drop down list when selecting "Save Copy In".
PT version 5.xx-6.9 is not an option for my situation. It needs to be a PT 7 session. Is there a way to do this?
Thanks
Old 05-22-2009, 02:19 PM
jmitchell1532 jmitchell1532 is offline
Default Re: Saving a copy of a PT 8 session as PT 7?
I think you just need to save it. The files themselves are backwards compatible (as far as I know) the only thing that wouldn't show up in 7 would be newer features such as the Midi Editor and any plugs not on the Version 7 system.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 05-22-2009, 03:10 PM
Thanks for the reply. I am using SSL's Pro Convert application to convert a PT session to Nuendo and It keeps telling me that there are no audio files in the PT session.
Pro Convert says it is only compatible with 5.xx-7.4. However, when I saved it as a version 5.xx-6.9 it still didn't work. So it very well may be a Pro Convert problem.
Old 05-22-2009, 03:13 PM
In Nuendo, just import the files from the PT session's audio folder. Wavs are wavs.
Jon
Old 05-22-2009, 04:01 PM
Gothboy's Avatar
Gothboy Gothboy is offline
Saving as "Latest" covers everything from 7 to 8.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
Old 05-22-2009, 07:32 PM
Its not quite that simple. There are over 160 tracks of a live show that runs over 3 hours long. There have been hundreds of overdubs on the original tracks and there are video files involved as well. There have also been tons of edits.
So rather than go in and clean up all the edits and consolidate 160 tracks that are over 3 hours each I am trying Pro Convert to see if it is up to the task.
Make sense?
Old 05-22-2009, 08:05 PM
rqstudio rqstudio is offline
When you 'save a copy as' are you checking the 'with audio files' box? (or are you even in that window?)
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 04:42 AM
Saving session copy and Altiverb IRs bad jitter Post - Surround - Video 3 08-27-2009 07:18 AM
-37 error when saving session copy SirLexelot Pro Tools TDM Systems (Mac) 3 03-25-2006 02:52 PM
Saving Session Copy files. new engineer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 10:29 AM
Saving a Copy of the Session Q Renie Pro Tools TDM Systems (Mac) 2 01-16-2002 02:51 PM
