Old 05-04-2009, 07:19 PM
Violet Violet is offline
Default Should I install PT 8 before or after I plug in my 002r that will install drivers?
I bought a new mac cause I could get PT 8 to work correctly on the last one. Hardware Buffer always came up and other various errors. Believe me I tried everything you could possible do to trouble shoot, including talking to 3 support agents.
I just want to make sure I get it right this time.
Please tell me in what order should I install protools?
Should I install PT8...
then plug in my 002r that will install the drivers...
and then plugins?
Or plugins first, plug in 002r w/drivers and then install PT8.
It probably doesn't matter but if someone out there thinks it does I'll listen.
Thank you.
PT 9.0.3
Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's
....and a couple other toys.
Old 05-05-2009, 12:01 AM
dougied dougied is offline
Default Re: Should I install PT 8 before or after I plug in my 002r that will install drivers
There are no "drivers" to install. (this isn't a windows system) Your 002R needs to be plugged in before you actually install PT.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 05-05-2009, 11:12 AM
DigiTechSupt's Avatar
Actually, not really the case - you don't have to have your hardware plugged in during installation on a Mac.
You do, however, need to have the 002R turned on before booting up the Mac and using Pro Tools.
Avid Audio Tech Support
Support FAQ
Unable to Re-Install 002 & 003 Drivers Bryn772 macOS 1 07-20-2012 04:03 PM
install Drivers PT 9 lowpez2 macOS 2 03-31-2011 11:04 AM
Install HD drivers? Boe Larsen Pro Tools TDM Systems (Mac) 2 01-08-2011 02:58 AM
Why install Pro-Tools to install drivers for Mbox2 bigbobbysd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2010 08:42 AM
Can't Install 002R drivers - Abit IC7-MAX3 jyang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-22-2004 09:55 PM
