Old 03-24-2006, 03:39 PM
SirLexelot SirLexelot is offline
Default -37 error when saving session copy
Hi everybody,
the other error I'm getting frequently when trying to save a session copy is the -37 error (again, Mac OSX 10.4.3 running Pro Tools 6.9.2 HD). What's really frustrating here is that it comes up halfway through the save. Is there any quick resolution to this problem? Thanks!!
Old 03-24-2006, 04:55 PM
Default Re: -37 error when saving session copy
You have multiple identical file names in multiple folders. ProTools tries to copy them all into one folder and returns a disk error when it tries to copy one file to that folder that is already there.
ProTools isn´t able to preserve your folder-structure when doing a "save copy in"
Try to hand-rename the duplicate files inside the session before doing this.
Frank.
PTHDn 2020.9 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 03-25-2006, 10:33 AM
Danny Caccavo Danny Caccavo is offline
It sounds like something else is going on here. When there are two files of the same name, Pro Tools will append a ".1" to one of the copies in order to put then in the same folder.
I'll let someone from tech support chime in here....
I'll see about adding "Preserve folder structure" to the list....but as you know, it's a long list.
Danny Caccavo
Digidesign
Old 03-25-2006, 02:52 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Danny, what happens here is from importing into various tracks you end up with FILE_A in folder A, and FILE_A in folder B. When you try to save a session copy of this it will not work properly. The .1 and .2, etc., only works if you import the same file into the same folder . . . it doesn't work with Save Session Copy In.
This scenario often happens in post, where you import some data from another session, import other audio with a third party device (such as SoundMiner), and import other audio perhaps using Import Audio. You invariably end up with identical files in various places. Consolidating this is not possible.
Unless this has been fixed in the latest CS release it has been a very problematic area with v7.
noise | jimlongo
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 04:42 AM
Saving session copy and Altiverb IRs bad jitter Post - Surround - Video 3 08-27-2009 07:18 AM
Saving a copy of a PT 8 session as PT 7? sodium glow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-22-2009 08:05 PM
problems with saving a session copy soundispatch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-22-2003 12:02 PM
Saving a Copy of the Session Q Renie Pro Tools TDM Systems (Mac) 2 01-16-2002 02:51 PM
